MitsuStyle
-   Brookdale Mitsubishi (http://www.mitsustyle.com/forums/forumdisplay.php?f=55)
-   -   oil pan gasket/bolts? (http://www.mitsustyle.com/forums/showthread.php?t=10343)
brently 02-10-2006 03:50 PM
Just wondering if you can get oil pan bolts? And how much for the gasket?
4g63t 6-bolt
-Brently
DSMPARTSGURU 02-10-2006 04:20 PM
Re: oil pan gasket/bolts?
BOLTS WOULD RUN $13.13 PLUS TAX.......
there is no gasket.... its silicone...
chris
brently 02-11-2006 07:35 PM
chris
ill take the oil pan bolts
also, Im still looking for a washer that was busted on my motor.. Is the a washer behind the oil pump sprocket? If soo, Ill take that if you can get it. thanks
-Brently
brently 02-11-2006 07:40 PM
heres the washer im talking about.
http://www.dsmtalk.com/gallery/uploa...e38are2_1_.jpg
I know this sounds bad, but its been a few months since the tear down, and I cant remember if this washer was infornt of the case or behind, but I know it was on the oil pump side.
thanks again
-Brently
EDIT: looks like its behind, since I can see some of the old case gasket on the block..
DSMPARTSGURU 02-13-2006 09:51 AM
is that spacer inside the oil pump housing???? i cant seem to find it anywhere>????
cc
c
brently 02-13-2006 08:30 PM
On one side i noticed gear marks. It looks like on the picture, the washer was sittin in the rear balance shaft, infront of the oil pump housing. Is there a washer inbetween the front case and oil pump housing?
DSMPARTSGURU 02-14-2006 08:01 AM
any help?? any one recognize this washer??? I dont see it in with the b/s shaft or in the oil pump????
chris
niterydr 02-14-2006 11:43 AM
No. There is no washer between the front case and the oil pump housing. there is a metal cap that threads into the outside that you can gain access to the balance shaft mounting bolt, but there is no washer between the gears and any portion of the aluminum case.
DSMPARTSGURU 02-14-2006 11:47 AM
brently does that help??
brently 02-14-2006 05:09 PM
yeah thanks guys!
Ill take the oil pan bolts still if you have them in stock.
Can you also check the price on a water pump and freeze plugs?
thanks.
brently 02-14-2006 10:20 PM
well, heres my last attemp for this "washer"
heres a pic of where it went. If this helps, if not, then screw it.
http://www.dsmtalk.com/gallery/uploa...ba03re2_1_.jpg
