1 Attachment(s)
This is Todd and Kate. I tried to enter as Super16G but it wouldnt let me :razz2:
Welcome again!! :D
Welcome back!
Welcome back!! :)
1997 Eclipse GSX
Modifications Go Fast: Engine: 1990 4g63 6 bolt block, balance shafts removed, fully balanced assembly, Unorthodox Racing underdrive pulley, TnT Motorsports oil cooler, fully ported and polished 2g head w/ cam angle sensor, HKS 264 cams, C&R aluminum radiator and spal fan, 180 degree thermostat and red silicone hose, ARP head studs, 4 layer Mitsubishi metal head gasket, Wiseco 9-1 forged pistons, Eagle H beam rods. Turbo: HRC Super16g turbo Fuel: ND 660cc injectors, 3000GT fuel pump Exhaust: HKS super dragger cat back system HRC eliminator jr. downpipe HRC O2 housing Air/Intake: Greddy front mount intercooler, Hahn Racecraft upper and lower intercooler pipes with Blitz BOV, K&N afck with injen intake, 1G throttle body, T & A motor designs ram air system TnT Motorsports racepipe. Drivetrain: Clutchmasters Stage 4 four puck clutch assembly, 4 spider gear center differential from Speed Design Exterior: 18" Enkei Zoku rims, 225/40/zr18 Yokohama AVS Sports Tires, carbon fiber altezza tail lights with painted center Vinyl stripes by Next Day Sign Co. Interior: Unknown Electronics: 12 Polk Audio subs all carpeted, flushed and installed by an expert, Alpine MRV 1000 Amp, Alpine MRV 250 Amp, Kenwood 10 disc changer, Kenwood 909 deck, Polk Audio 6x9's, Polk Audio component set. Suspension: Eibach drop springs, Pilot upper strut bar, Tokico 5 way adjustable struts, TnT camber correction kit, 13" Baer big brakes with steel braided lines |
Do you have any pictures of the stereo? :bowdown"
1 Attachment(s)
:toast:
Very nice, I wish my 1g didnt have that stupid bump so i could have a flat floor. Do youhave a spare under there or just empty.
1 Attachment(s)
We do have the spare and after the Chicago Hot Import Night when we lost a tire on the way back I 'm glad that we do :)
http://www.springfieldmortgage.net/f.../T3T4wstgt.jpg
-------------------------------------------------------------------------------- http://www.springfieldmortgage.net/f...Dyno%20run.jpg -------------------------------------------------------------------------------- That was only at 17 psi....We are going to run at least 24 next pull and if everything is solid turn it up to 30psi |
Welcome :)
car looks awesome
30 psi on a 16g eh? :goodluck:\ |
:naughty: The one on the left is the old Super16G the one on the right however is the new Turbo :jammin:
http://www.springfieldmortgage.net/f...s/T3T4S16G.jpg |
I think you mean the new one is on the left and the old ne is on the right ;)
DOH!!!!!!!! :uh:
Hey what kind of SS exhaust manifold do you have? Is it custom?
That is a new brand out. You can see their stuff at www.soontobecrackedandfallingapart.com
Ask Chris Carey about that! |
ohhhsss nooss, don't tell me you bought an SSautochrome thing too???
Yeah it's a big hunk of Poopie......I will be hacking it all up,rewelding it and sending it off to be jet hot coated..Kinda came with the set up..Long story but I'm kinda stuck with it for now....I hope the reworking of it will hold up :)
Well, if you want it done right, look me up. I am in the process of making a kiln to stress relieve exhaust manifolds and O2 housings. This is key to making one live without cracking. The stress left in the welds is a big part of what causes the cracking.
| All times are GMT -5. The time now is 05:39 AM. |
