MitsuStyle
-   Turbo / Engine / Drivetrain (http://www.mitsustyle.com/forums/forumdisplay.php?f=91)
-   -   Turbonetics Rebuild or CHRA Swap? (http://www.mitsustyle.com/forums/showthread.php?t=17073)
thom1301 09-27-2007 09:00 AM
My little brother's Turbonetics 60-1 took a crap. He thinks he needs an exhaust wheel, the shaft, and new bearings and seals. Evidently the Turbonetics stage 3 wheels (with larger 5/16 shaft) have been discontinued and replaced with F-1 wheels, which will not work with his exhaust housing. So he has been told he can either replace the exhaust housing and update everything to F-1 spec, which would supposedly cost him 7-800$, or he could upgrade the center section to a BB Garrett T-series CHRA for about $900.
Is there any reason he should or shouldn't do either of the above? Which would you recommend?
Pushit2.0 09-27-2007 09:32 AM
Re: Turbonetics Rebuild or CHRA Swap?
How about buying a more modern turbo? The 60-1 sucks at life, we could price him a new PTE turbo, it would be a little more then the rebuild but worth the money, or search for a used turbo.
Shane@DBPerformance 09-27-2007 12:23 PM
Buy a different turbo.
thom1301 09-27-2007 12:55 PM
I guess he could solve his internal wastegate problem at the same time...
Shane@DBPerformance 09-27-2007 01:37 PM
The 60-1 is an older outdated turbo that have mostly been replaced by 61mm based turbos that spool up the same and make more power. I wouldn't recommend getting a turbo rebuilt, 75% of the time they fail again very soon after.
Capinoy123 09-27-2007 05:49 PM
I personally would buy a FP turbo! those are well worth the money! I know from experience.
