MitsuStyle
-   Modern Automotive Performance (http://www.mitsustyle.com/forums/forumdisplay.php?f=70)
-   -   AEM Wideband UEGO Gauges Just $254.99 / 5 In Stock! (http://www.mitsustyle.com/forums/showthread.php?t=18059)
4Las90 01-03-2008 06:16 PM
Click here to purchase one at this limited time sale pricing!
http://www.aempower.com/images/categ...83f68561e6.jpg
AEM Gauge-Type Wideband UEGO Controller
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
* Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
* Does not oscillate AFR reading like narrow band sensors
* No laptop required for monitoring!
* Bosch sensor included
* Accurate to 0.1 AFR
* Reads in AFR or Lambda via a switch in back of gauge housing
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
* Integrated three-digit display reveals AFR or Lambda in real time
* User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
* Serial data stream included for output of AFR (RS 232)
Frequently Asked Questions
AEM FAQs - Gauge Type Wideband UEGO Controller
Dizmm 01-03-2008 06:54 PM
Re: AEM Wideband UEGO Gauges Just $254.99 Shipped!
How long will this sale be going on?
v8klla 01-04-2008 12:56 PM
Until we sell the 5 we have in stock ;)
Chris
X Factor 01-05-2008 09:05 PM
Re: AEM Wideband UEGO Gauges Just $254.99 / 5 In Stock!
I might be interested in one of these... I might have to give you a call, because I have a few other things in mind.
v8klla 01-05-2008 09:08 PM
Sounds good please do!
Chris
