MitsuStyle
-   Brookdale Mitsubishi (http://www.mitsustyle.com/forums/forumdisplay.php?f=55)
-   -   flywheel Bolts and AT spacer (http://www.mitsustyle.com/forums/showthread.php?t=19991)
carltalon 07-04-2008 07:28 PM
I need price and avalibility for
6 1990 DSM flywheel bolts Manual transmission
1 MD005994 9 x 14mm alignment dowel
1 MD952138 Auto Spacer plate
Thanks
Super Bleeder!! 07-05-2008 03:29 AM
Re: flywheel Bolts and AT spacer
You may want the auto bolts, as they are a bit longer than the manual ones to make up for the spacer.
carltalon 07-05-2008 10:24 AM
The info I got says that the 1g Manual is the longest stock bolt I can get.
Various stock flywheel bolts lengths:
1G M/T Bolts 12x22.5mm
1G A/T Bolts 12x17mm
2G M/T Bolts 12x21.2mm
2G A/T Bolts 12x11.7mm
If this is wrong Id like to get the longer ones.
Super Bleeder!! 07-05-2008 01:45 PM
Jet posted this awhile ago.
I ended up using the stock Mitsu bolts for an auto car. You will need to check the depth of the threads to make sure it will work. If you screw it in all the way and have less than .660" from the top of the bolt head to the end of the crank, then you are ok and can just use the longer bolts and auto spacer plate. Note, this is for a twin disk with a .315" thick flywheel (standard PTT). It *should* work with a regular clutch too, but double check the measurements.
Nick G 07-08-2008 11:45 AM
spacer md952138 $9.76 need to order
dowel pin md005994 $2.64 in stock
flywheel bolts 12x22.5 2795a956 $0.94ea (6 on hand)
let me know
thank you!!
Nick
carltalon 07-08-2008 06:44 PM
let me know
thank you!!
Nick
Go head and ordere the spacer and I'll pick it all up when the spacere comes in.
Just for reference are the 12.22.5mm bolts the auto or manual bolts?
Nick G 07-09-2008 11:42 AM
12x22.5 mt
12x17 at
should see monday
if you need before that let me know
thank you!!
Nick
