i submit that they do not.
I don't even have mine in my car anymore.
Never have.. a stick works dandy because Im not paying 40 bucks for those shitty things.
try a junk yard and that might help a little bit to at least help hold it up better even if you do need to use a stick.
That's what the vice grips in my trunk are for....I kept knocking over the stick I used before and closing the hatch on myself :headache:
Mine work because I spent the $40 to fix them. All I have to do is start to lift the hatch and it goes up by itself.
I used the stick too until I fixed them. I used to use vise grips on my CRX until i almost broke my arm when the visegrips popped off and the hatch fell. Another trick is to extend the arms all the way and then put a SLIGHT bend in it. Just pull the center of the arm towards you to put a small bend in it. Then when you want to close it just push the arm forward in the center while lowering the hatch. |
white Talon: yes
beater Talon: who cares? |
oops, I voted no and mine do work. They didn't until I got a set off a jucker at hennipen tech last year. I got both (aftermarket shocks) for $1. Definitly the best dollar I have spent on my car.
My car doesn't have those persay, buy the torsion style springs it does have work! :banana:
ive owned 3 dsm's, none have had working ones
I don't have a dsm yet, but the ones on my integra worked until I put the bigger wing on it.
your integra has nothing to do with what we are talking about. :rant: ive owned two dsms and niether has had working lift arms in the trunk.
my stealth's work, both of my dsm's i've owned haven't worked.
I don't even know, but by Swanny's response I'm guessing not. :P
LOL. My old 1G they worked awesome!
Yeah, the pair I got at Hennipen tech for $1 were some aftermarket ones. I always check at the junkyards for good ones but they are either gone or there is no glass in the hatch where as they aren't supporting any weight.
| All times are GMT -5. The time now is 07:11 PM. |
