MitsuStyle
-   The Parking Lot - On & Off Topic (http://www.mitsustyle.com/forums/forumdisplay.php?f=21)
-   -   Update on the Car progress - (joining Jet) (http://www.mitsustyle.com/forums/showthread.php?t=8567)
SlowWhite 08-19-2005 08:37 PM
Well to go along with Jet's thread. Started the car for the first time today. Everything went perfectly. Tranny's still in one piece (hahaha)
Changed the Oil and Filter and then Went for a Drive around the Townhouse complex (18 buildings with some straights, and several turns would make for a fun road coarse if it wasn't for the speed bumps) Anyrate didn't put the hood on at this point temps stayed low, but she ran fine (stalled alot) as the idle was really low and I was out of Gas (like coasting into the gas station out of gas)
So Mike had to go home, so I made this an opportunity to drive the car to his place and back. (ended up being 26 miles round trip) Hit up the gas station fixed the idle but then the trottle went up to 1600rpms, so I had to adjust the throttle cable. (no biggy) and all was well.
Basically it's a 5 turn event from my house to his with plenty of open/back roads. So did several back to back pulls 3K-4500rpms getting on boost till 5psi and then coasting back down to 3K.
Everything was going well Intake temps were up to 196 occasionally went up to 216 when I was going slower then 40mph.
I had some concern on the way back that I might need to switch to a lower thermostat. (ie: my previous 2G motor I had to go from a 180 degree to a 170 just so that my temps would go down from 216 to 190) Might have to do that same thing here. As on the way back I got stuck at more stop lights then going there and my temps were always at 200 when driving (less then 40mph) and when stopped it went up to 230.
Coolant isn't bubbling it's totaly fine Oil level is perfect and I didn't see any spots when I left Mikes or my place. She's parked for the night and the garage is clean so we'll see what the morning brings. but so far so good.
I'm seeing 5 psi by 3300 rpms which I think was much sooner then my previous motor.
I have noticed it definetely needs tuning in the lower rpms. It stutters alot when I hit the gas. then gets up and goes. I should have taken picts and posted them but I'll do that tomarrow.
A//// Guy 08-19-2005 08:43 PM
Re: Update on the Car progress - (joining Jet)
230 is way hot for the motor. A lower thermostat is not going to lower your temps from where you are at now, its only going to delay the heat up process on initial driving. You need some stronger fans or something to improve flow to the radiator- obviosly your not getting enough air to cool the coolant when standing in traffic.
I have the same problem when it gets 90+.
niterydr 08-19-2005 09:04 PM
Looking good brian, but find a way to get those temps down!
SlowWhite 08-19-2005 09:31 PM
Not sure how other then continiously driving. I have a fluidyne Radiator and 2x1000CFM Fans already. I'm using 90% Water and 10% coolant. Everything is brand new. But it's this damn heat down here. Heat index today was 105.
Temps stayed under 200 when we were actually driving wasn't till I continiously hit every Light and Traffic on the way home that it went up. But I will say the under hood temps are just rediculious like always. I already removed the rubber rain guard when I was still in MN to help battle the high temp issues I was having, (normal driving temp was 216 and 220 when on boost) Only thing that helped was when I lowered the thermostat. Then it just stayed in continious loop.
Also I always have 1 Fan on at all times. the 2nd fan turns on when I push the A/C button. When the temps get over 220 I turn the 2nd fan on and the temps come down.
I'll check the coolant level tomorrow the motor originally on warm up used a lot of coolant from the overflow bottle, I refilled it up and on the 1st and 2nd trip it didn't move at all. man does that radiator stay hot though. I went out an hour or so later and it was still hot to the touch. But then again even though it's 10:30 it's still in the upper 80's here. And humid as hell. (you just drip with sweat as soon as you open that door)
SlowWhite 08-20-2005 09:34 AM
well went out this morning and checked the car over. Coolant was still full, and the oil is fine, not a drop on the floor.
Hopefully Jenny and I will take her for a spin in a little while for lunch and then on a few arrends
SlowWhite 08-20-2005 09:52 AM
3 Attachment(s)
Here are some picts of the Motor along with the Cage painted.
SlowWhite 08-20-2005 09:54 AM
3 Attachment(s)
More pictures of the new Cage
SlowWhite 08-20-2005 09:55 AM
Yes I still have the Torino's in there. But getting the Car running was my first goal before I trade them up for the Pro2000's.
TheBlizzard 08-20-2005 10:00 AM
Looks good Brian.
SlowWhite 08-20-2005 10:03 AM
sorry about some of the picts being a little blurry. That's what happens when you walk outside from an airconditioned place into the heat cause it's so damn hot. (at 8am this morning it was 89 outside) I kept having to wipe down the lense and then take a shot, re wipe down the lense...
slowbubblecar 08-20-2005 10:18 AM
That manifold looks familliar
SlowWhite 08-20-2005 10:52 AM
Which manifold? the T3/T4 turbonetics or the Magnus 1G SMI?
JET 08-20-2005 10:55 AM
Looks good Brian, gratz on getting her up and running again!
slowbubblecar 08-20-2005 11:36 AM
turbonetics. I have the same one.
niterydr 08-20-2005 03:13 PM
Damm it looks good.
Nash 08-20-2005 04:11 PM
Lookin' good Brian!
niterydr 08-20-2005 09:36 PM
Hey brian what did you do with the shipping valve cover?
SlowWhite 08-21-2005 10:17 AM
It's now covering my 2G Head that's still in my garage.
SlowWhite 08-22-2005 11:14 PM
Well the car is now up to 122miles. time for the next oil change. Took Jenny up to moroso this evening when we started the trip I was only at 73 miles. I drove her around the Pratt and Whitney Space Division first.
FattyBoomBatty 08-22-2005 11:41 PM
hey mang, if you mix coolant and water (distilled) correctly, you get a higher boiling point as well as freezing protection. pretty much 50-50, as everyone knows.
chemistry will blow your mind.
