Old 04-16-2006   #1
LaunchHard
LaunchHard's Avatar
Advice on wiring an SAFC II
I need to wire an my afc into my new shell, and i don't have any sort of wiring diagram. I did however, write down what wires it was connected in the old harness. My question is do you guys have any advice on how to wire it in, and what to use to connect the wires? Do some connectors work better than others?
Old 04-16-2006   #2
Re: Advice on wiring an SAFC II
Soldering works the best.
Old 04-16-2006   #4
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
definitly solder and heat shrink heres the wireing http://www.knight-rider.org/mn-dsm/tips/SAFC2.jpg
11.35 @ 120mph
Old 04-16-2006   #5
LaunchHard
LaunchHard's Avatar
I was thinking of using those connectors that you heat up, and when you heat it, it solders itself and heat shrinks at the same time. The only problem is is i don't know how safe the other wirs will be from the heating torch.
Old 04-16-2006   #6
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Yeah those work good as well. They can be tricky in tight spots though. I used a portasol soldering gun and heat shrink on mine and it worked great and looked clean.
Old 04-17-2006   #7
LaunchHard
LaunchHard's Avatar
When I disconnected the wires from my car, There were three wires that weren't connected to anything. Any ideas? I can post which colors they were for sure later, but i think they were blue, yellow and white.
Old 04-17-2006   #8
blageo23
AWD4G64
blageo23's Avatar
I just did mine, the white and yellow go where the pink and orange go on a different car. We have a sensor that is a Karman type so we use the pink and orange instead of the white and yellow. The blue is for a car with an RB26DETT.
Found here on page 8 and 9...
http://www.apexi-usa.com/pdf/technic...tation/202.pdf
Mike
Old 04-17-2006   #9
LaunchHard
LaunchHard's Avatar
Thanks a shit load for the advice guys I'm gonna get it done tonight.
Old 04-17-2006   #10
I've wired AFC's into about 25 DSM's with the red clips you fold over and squeeze with a pliars and never once has a single wire come loose. This method is much easier and faster IMO.
Old 04-17-2006   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Those work good if you are talking about the ones we use for installing car alarms and remote starters. They are called T-Taps. They fold over the wire you are tapping into and then you plug a male spade connector into it. Makes it easy for quick connect/disconnect and you arent hackin up a bunch of wires. I've never had any problems with them either.
Originally Posted by shoutbox
Old 04-18-2006   #12
LaunchHard
LaunchHard's Avatar
I soldered it up last night, but the shrink wrap was getting in the way so i just used electrical tape over the solder. Thanks for all the help though.
Old 04-20-2006   #13
LaunchHard
LaunchHard's Avatar
Today, went to connect the afc to see if it was working. The it position isn't working. What color wire is that, so that i can check the connection.
