Old 04-26-2006   #1
TalonTSI95
need 14b gaskets, bolts, and more...
i need all of the gaskets, oil lines, and bolts needed to install a 14b on a 2g dsm. i already have a j pipe and LICP
TalonTSI95 is offline   Reply With Quote
Old 04-26-2006   #2
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: need 14b gaskets, bolts, and more...
Is 14b 1st gen? is it at or mt?
Nick G is offline   Reply With Quote
Old 04-26-2006   #3
TalonTSI95
14b is 1st gen turbo, but its going on my 2g. its a MT.. 97 GST spyder. also how much would it be for shipping to zip code: 56345 ... because i am not sure if i want to drive all the way down there from saint cloud with gas being so expensive. but if i must then i will.
Old 04-26-2006   #4
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
Not sure what all is needed and what it takes to convert. looking at the oil lines,bolts,gaskets for 1st gen your cost $84.36
Old 04-26-2006   #5
TalonTSI95
this is the list i got from a fellow dsm member
-turbo outlet/J-pipe gasket
-turbo to o2 housing gasket
-manifold/turbo bolts (4)
-crush-washers for water in/out lines
-crush-washers for oil feed (4)
-gaskets for oil drain (2)
New braided stainless steel oil supply line
New 7cm gasket for the turbo to the manifold
New 2 1/2" down pipe gasket
i believe this should be the complete list... of everything!! you check out any prices on shipping stuff for me?? thanks.
Old 04-26-2006   #6
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
OK
I cant get the braided lines, I stock the rest your cost $60.20+ tax
Old 04-26-2006   #7
GVR-4579
i have used crush washers, banjo bolts, and some cut off coolant lines if they will help you out
