Old 05-05-2006   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Intercooler Corrosion
Well The outlet pipe on my intercooler has holes in them. What do I do to fix this? Do I need to buy a whole new intercooler? Does anyone have one laying around from converting theirs to a front style?
THIS DOES EXPLAIN THE BOOST LEAK PROBLEM!!
Old 05-05-2006   #2
Re: Intercooler Corrosion
Find a new one. Stock sidemounts can be easily found for <$100.
Old 05-05-2006   #3
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
You could have a new elbow/outlet welded onto it. But when you are all said and done you could have just gotten a used side mount for a bit more.
Old 05-05-2006   #4
Quickest and easiest solution is to wirebrush the in/outlets really well and then cover each in a nice smooth layer of JB Weld (QuikWeld works too), let it cure, then bolt everything back up. Bye-bye boost leak, hello $3 fix
Old 05-05-2006   #5
Andrew7dg
Andrew7dg's Avatar
I think it will get the JB weld for right now and soon it will recive a FMIC I will keep everyone posted though how the JB works!
Old 05-07-2006   #6
Andrew7dg
Andrew7dg's Avatar
Well I have to tell you it acts like a whole different car. It has power!
The JB weld is holdingup for right now. We will see for how long. I will price around for a different side intercooler. It shouldn't be that hard to find one.
What I can't believe is how long the previous owner was driving it around like that. It would have drove me nuts. I hope this helps my gas milage now that I have fixed the boost leak (major boost leak!)
Old 05-07-2006   #7
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I would of Duck tape it.j/k
Take her to the limit!
Old 05-07-2006   #8
The JB Weld will hold for longer than the rest of your intercooler lasts, don't bother buying a new one. I used mine for another 2 years after JB Welding it and when I took it off it still looked perfect.
