Old 05-21-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Which gaskets should i use??
Whats up everyone i am in the process of puting a 1g motor in my 2g. My questions is which head gasket to use becuase i am doing a 7bolt head and 6bolt block for now, untill i get my 6bolt head fixed up. But if i do that combo 7bolt head and 6bolt block which gasket set should i get a 6bolt or 7bolt? I appriciate the help i just couldent find it anywere.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 05-22-2006   #2
96 Gsx Awd
96 Gsx Awd's Avatar
Re: Which gaskets should i use??
I think i figured it out, i need a 6bolt bottom end and 7bolt top end, and the head gasket dont matter it fits on both generations. Is this correct?
Old 05-25-2006   #3
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I think the coolant passages are different 6 bolt to 7 bolt.
- Josh L.P.
Old 05-25-2006   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
They are both the same. We used a 6 bolt hg on a 6 bolt with a 2g head a long time ago to get rid of a car.
7/25/09
Old 05-25-2006   #5
96 Gsx Awd
96 Gsx Awd's Avatar
I had Slowboy Racing tell me what i had said, that was my source thanks
Old 06-06-2006   #6
acidrumz
mitsu metal hg should be good for you. you can opt to use copper seal on the hg before installation.
