Old 06-22-2006   #1
Tauni
Mazda-ing
Tauni's Avatar
Drives: 2013 Mazdaspeed3
E-brake Question
Car: 1990 Eagle Talon TSi AWD Stock.
The E-brake has been out of commision since I bought the car. Basically what happens is when you engage it, the rear drivers side caliper siezes up and you have to take the whole wheel off to fix it.
My question[s] are:
1. Why does it do this?
2. How do I permanently fix it so I can use my e-brake again?
Old 06-22-2006   #2
Re: E-brake Question
The rear calipers on 1G's are notorious for locking up. They rust and bind, mostly from lack of use of the e-brake. You can try taking it off and working it back and forth with some WD-40, or pony up for a new caliper, which is probably the better idea if you've got the scratch.
Old 06-22-2006   #3
Yea rebuilt my rear calipers twice in 4 years because they kept seizing... I just ended up not using the ebrake much at all. Just parked in gear all the time.
Options:
Rebuild them and hope they dont seize again or buy a new or refurbished unit.
Old 06-22-2006   #4
Best option: Buy a reman'ed rear caliper. Autozone sells a pair of rear calipers with pads for $80.
Old 06-22-2006   #5
Tauni
Mazda-ing
Tauni's Avatar
Hm. Well thanks guys, good to know! I'll just kepp parking in gear for awhile
Old 06-23-2006   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Tauni, i can take a look at them if you come over to have me fix the turbo feed.
Old 06-23-2006   #7
Tauni
Mazda-ing
Tauni's Avatar
Sounds good!
Old 06-23-2006   #8
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
80$ for the pair ??? (Grabs check book, and walks out the door.)
11.35 @ 120mph
Old 06-23-2006   #9
Shane55113
Now 20% less Racist
Shane55113's Avatar
any one know how to fix a snapped cable for the e-brake?
Old 06-24-2006   #10
iceminion
iceminion's Avatar
go to your local auto shop, and buy a new e-brake cable.
building a 3000GT AWD Turbo.
Old 06-24-2006   #11
acidrumz
the e-brake cable from the dealer shouldn't be too bad...i think i got one a while back for $90. you gotta get the correct side too if i'm not mistaken. rust is also a pain if you snap some bolts.
later.
