Old 09-15-2006   #1
blageo23
AWD4G64
blageo23's Avatar
98 ECU In A 95
Will a ECU out of a FWD 98 work in a FWD 95? Also is there a difference in AWD and FWD ECUs in the 2G?
Old 09-15-2006   #2
Re: 98 ECU In A 95
If you rewire the injectors at the ecu and swap the spaark plug wires around it will work fine. You might be able to figure out an easier way to get around the injector firing order by studying the way the 1G motor in a 2G wiring trick is done for 95-96 versus 97-99.
Old 09-15-2006   #3
blageo23
AWD4G64
blageo23's Avatar
Re: 98 ECU In A 95
Ok thanks! But is there a FWD and AWD difference?
