Old 09-25-2006   #1
tjg
engine life
Idk if i'm supposed to post here but this is the question. I have a 96 talon awd tsi and it has 198 xxx miles on it and have no idea on the motor. I was wondering how much life does it have left in it, it runs smooth and everything i bought it with a shelled transmission, and i'm getting a transmission for it in a week, think it will be ok?
tjg is offline   Reply With Quote
Old 09-25-2006   #2
Re: engine life
Idk
Old 09-25-2006   #3
Re: engine life
How about doing a compression test? That's a BIG indicator of what's going on.
Old 09-25-2006   #4
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: engine life
Arn't the 96's subject to crankwalk? If so then 198,000 is hella good!
pics or gtfo
Old 09-25-2006   #5
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: engine life
You have until exactly 201,938.65 miles before it fails. Every dsm ever made does this, we call it the DSMY201.93865K problem.
Old 09-25-2006   #6
tjg
Re: engine life
So if i do a compression check what psi should it be for a 2g ?
Old 09-25-2006   #7
Re: engine life
I believe around 180 PSI or so was factory, if you're above 160 in all holes you're in good shape.
Old 09-26-2006   #8
tjg
Re: engine life
I did a compression check, 3 have 180 psi the other is barely 160 psi.
Old 09-26-2006   #9
Re: engine life
Thats not bad at all for your engine. I'm guessing the 160 was in hold #2 which always runs the leanest (2nd from driver's side).
Old 09-27-2006   #10
tjg
Re: engine life
Yes, your exactly right, so my engine is good and i shouldnt have any problems
Old 09-26-2006   #11
Re: engine life
for 190k, your motor seems to be in the better half.
Old 09-26-2006   #12
Gravy
Who's this guy?
Re: engine life
You may be in the same boat i am, check your coolant level often, see if your losing oil or coolant from the engine. If your not losing fluids, your clutch doesn't go out on you too often(normal driving) and your gears don't grind. She's good as gold!
Old 09-27-2006   #13
Re: engine life
Anything's possible, but right now its looking strong at least.
