Old 12-22-2006   #1
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
2g Maf 1g car w/ 650's
I do not have an eprom. I know that 650's with just an SAFC makes it difficult to tune. Because you subtract so much fuel, and the ECU goes to the map for that amount of airflow, and your timing becomes way off from where you want it to be.
So I read that for the 1g guys upgrading to the 2g maf makes it pretty much a bolt on for 550's. I think -24 for 550s +22 for 2g maf. Something like that. So I was thinking... Going with 650's on a 2g maf would be like tuning for 550's on 1g maf. It would be easier. Get what I'm saying? Am I thinking correct? Has anybody done this setup before? If so, good results?
2004 Dodge SRT4. Bone Stock
2006 Toyota Sienna. Swagger Wagon
SOLD 1992 Plymouth Laser AWD. 13.4 @ 102 Stock tune and turbo.
turbo2086 is offline   Reply With Quote
Old 12-22-2006   #2
Re: 2g Maf 1g car w/ 650's
It'll work fine. Does your setup require larger than stock injectors though? You should give us details on your car so we can give you the best possible advice.
Old 12-22-2006   #3
The 550's NEARLY balance out for a 2g mas swap. We have discussed this before on this forum...try digging around a bit.
The 650's work okay on a S-afc..I would recommend to just take it somewhere to get tuned. I charge $150 to setup S-afc's and tune them for high/low.
Old 12-22-2006   #4
Too bad you don't have an EPROM. I have 2 chips sitting here that are for a 1g with a 2g MAS, and 660's.
Old 12-22-2006   #5
A 2G mas would make it much easier, plus it looks way better.
Old 12-22-2006   #6
turbo2086
turbo2086's Avatar
Okay well what's on the car now...
Free Mods
Datalogger
EGT, boost readouts
Ported Evo III Manifold
Ported 14b
Ported 2g o2 housing
3" Turbo back exhaust
Walbro 190
Dejontool UICP
Bpr7es plugs
Act 2600 w/ street disc
Boost controller.
Purchasing a FMIC kit and ARP head studs next week.
Then I would like to run the EVOIII turbo, but want to get my fuel stuff done first. So leads me to this thread.
Old 12-22-2006   #7
tim
tim's Avatar
If you dont have the SAFC yet you could go for the EPROM instead. Have it tuned and a chip burned(or buy Brandons). Then if you ever do the DSMlink route you would be set.
Old 12-22-2006   #8
Get one.
http://www.dsmchips.com/
Old 12-23-2006   #9
or just get DSMLink.
Old 12-23-2006   #10
Shane55113
Now 20% less Racist
Shane55113's Avatar
Old 12-23-2006   #11
turbo2086
turbo2086's Avatar
Trust me, I would go DSM link if I had more money lying around. For what I want with my car I can do without DSM link.
2gmaf 70bucks used
SAFC II 200bucks used or
Eprom 200+
DSMLink 500 being the lowest I seen.
Old 12-23-2006   #12
I would do the 2G MAF and EPROM. I do custom chip tunes on 1Gs with just an EPROM ECU. It's a lot better than the SAFC route. Running 650cc injectors with an AFC and 2G MAF will cause the ECU to want to run a lot of timing at pump gas airflow levels. Even though doing a 2G MAF with 550s almost evens out, all it is doing is reporting less airflow to the ECU, which is just like doing it with the SAFC itself. Running 650s on a 1G DSM without changing the injector scaler in the ECU will require lowering the airflow reported to the ECU by 30+%, which can cause problems on some cars that aren't exceeding the top airflow row of the timing map by that same 30+%.
You could do a generic chip in an EPROM ECU setup for your injector size/2G MAF and then fine tune it with the SAFC also. Then atleast you would be closer to start with and not have to go as far negative on the SAFC.
Old 12-26-2006   #13
What do you charge for EPROM chips?
Old 12-26-2006   #14
I usually do them custom on the dyno. So it's dyno time. But if you just wanted a generic one for your setup and any special requests, if you want some special ignition timing or something, then probably like $50.
