Old 02-04-2007   #1
kennydawgg
injector Resistor pack how to help
anyone know how to make a resistor pack for my spyder?
I have an e-manage, 450 cc injectors and I am working on building the system to add boost. From what I am reading the e-manage will control high imp. injectors without a problem but when you want to add the low you need the resistor pack built into the line. Also from what I am reading the gst/x have these built in. knowing that resistors cost less than a dollar i would rather make one than spend a hundred dollars buying a stock one.
Can anyone help me out.
thanks
kenny
kennydawgg is offline   Reply With Quote
Old 02-04-2007   #2
Re: injector Resistor pack how to help
Why not just get high-impendence injectors? And those resistors u can get for less than a dollar aren't suitable for underhood use, being exposed to weather and such extremes.
Old 02-04-2007   #3
You might be able to get a stock used resistor box from a turbo DSM or older Honda for $10-$30. Otherwise goto Radio Shack and find some 4 10 ohm resistors.
Old 02-04-2007   #4
kennydawgg
would I wire them inline on the same wire as the e-anage hooks to (the wire from the ecu to the injector)?
