Old 04-03-2007   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Alternator interchange between Turbo and NA?
I have been having electrical troubles with my car lately. Every once in a while this problem happens. The cars electrical system dies. It has to be the battery or the alternator. I had them both checked lately, the battery at sears and the alternator at redrooster where they hooked up something to measure the draw. Both checked out fine.
However the car doesn't seem to be holding a charge. Started the car up this morning, drove a short distance, the wipers were going slow, then the radio died, shut the car off and tried to start it again and it just turns over very slowly...
So since the battery checked out fine, I am thinking it is the alternator isn't putting out consistanly... any other ideas what it could be??
This car is a 1993 gs and I am going to try to swap alternators from a turbo and I don't know if they are the same
Old 04-03-2007   #2
Re: Alternator interchange between Turbo and NA?
Should be. The turbo alternator might be a higher amp model, but it depends more on the original option list.
Old 04-03-2007   #3
Andrew7dg
Andrew7dg's Avatar
I just talked to the autoparts store and they told me it is a different model number....
So the question is will this still work? They told me it depends on if the car came with an automatic or a turbo...
they have to be really really really close!
they are both 4g63 motors
Like you said it may be just a higher amp model
We will just have to wait and see what happens!!!!
Old 04-03-2007   #4
DSM_421
Sounds like the alternator to me. Good luck with that hehe.
Old 04-04-2007   #5
Andrew7dg
Andrew7dg's Avatar
It works just fine!!!!!
However what did the other alternator in was that power steering fluid was leaking onto the alternator. It is still leaking! I have clamped the nut on the top of the banjo down tight.... leaks...used a washer...leaks....use a copper washer.... leaks...used gasket sealer... leaks.... What the heck is going on! I am ready to remove the power steering pump completely!
Old 04-04-2007   #6
95talonracer
95talonracer's Avatar
Check for cracks or pin holes in the line it self I have had this happen.
Amsoil Dealer
Old 04-12-2007   #7
there is 2 orings on the line that need to be replaced
Old 04-12-2007   #8
1G MT: 65 amp
1G AT: 75 amp
GVR4: 90 amp
(these are aprox. numbers, they may not be dead-on accurate)
