Old 05-01-2007   #1
tnm27
I'm the short one.
tnm27's Avatar
oil pressure light is on
Hey there guys, I have a some what simliar problem to like Bks5otrimGST, upset that mine is a 91 GSX. After the car warms up, if will drop below 1,000 rpm to about 600 rpm. When it does the oil pressure light turns on and it kind of studders like its going to die (similiar to a small vaccum leak). Also, my oil temp gauge fluctuates up and down, and will never stay at one spot. Has any one ever had this problem occur to them? if so, than how do you go about getting rid of this problem.
tnm27 is offline   Reply With Quote
Old 05-01-2007   #2
Re: oil pressure light is on
Rase your base idle to 750-800ish check your base timing, and do a boost leak test.
Old 05-05-2007   #3
mdost03
Sonic Champion!
Drives: VA STI
Do you have an aftermarket oil pressure gauge? IMO, that is a necessity on a turbo car. If you do, what kind of numbers are you seeing for pressure when the light comes on?
