Old 05-18-2007   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Checking for Crankwalk
I'm trying to see what techniques people have used to check for crankwalk. I know there is this one: http://www.angelfire.com/pa4/awdcrankwalk/ which I'm going to give a try. Has anyone else had success with this technique? or advise another technique without having to take off the oil pan? And is 0.006" the amount of play that classifies it as a walking crank? Thanks in advance.
Old 05-18-2007   #2
Re: Checking for Crankwalk
I would use a dial indicator on a magnetic base, but that procedure will work pretty well. It will give you a ball park anyway. .006" is good. I think factory is .009" for the top of the spec, if you are at .015" it is starting to go. I had one come it at over .060" and it still ran, but was on its last leg. It was having shifting issues.
Old 05-18-2007   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Ok, cool. Thanks JET.
Old 05-18-2007   #4
driftn1g
Whats crank walk?? and should i be worried???
what does it do to your car?
Old 05-18-2007   #5
Kills your engine, but you have a 6 bolt so everything is cool. 2g's get it the worst.
Old 05-24-2007   #6
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
uhm.. so yea we checked for crankwalk today but we're not sure about the numbers. We got .008-.010.. and then .025 but I duno about that last one, lol.
