Old 07-20-2007   #1
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Twin Disc Opinions
Powertrain Technology Twin Disc
Quarter Master Twin Disc
Other Brand... Exedy, HKS, etc.
Search – revealed there are a few of you who are / was running the Quarter Master Twin Disc. Powertrain Technology experience, anyone?
What are your thoughts and reflection? Would you purchase it again if you needed to? Or would you purchase another brand?
Old 07-20-2007   #2
v8klla
v8klla's Avatar
Re: Twin Disc Opinions
We are very happy with the QM and have used it in two 650whp+ cars. We chose it over the PTT based upon the disc material. I *believe* the QM is a ceremetallic material where the PTT is organic. The best part about the clutch is if it slips a little bit, heat it up some more and it goes away!
We are going to throw some more at it tonight and this weekend to see how well it does in excess of 709whp
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 07-20-2007   #3
v8klla
v8klla's Avatar
Also, regarding the other brands Exedy is currently redesigning the 6 bolt twin disc as they didn't hold much over 400 ft/lbs and I have heard numerous horror stories in regards to the Clutchmasters so I would stay away from those two.
Carbonetics just released a full carbon twin disc for the 6 bolt application that looks to be an awesome piece, but it is VERY expensive.
And time for a shameless plug...
We also happen to sell all of these at some very competitive pricing
Chris
P: 763-545-3800
Old 07-20-2007   #4
Enes
Enes's Avatar
i'm also did some research on this and saw the horror stories too..
What are some prices on them these days specificly for a fwd 7bolt
Old 07-20-2007   #5
v8klla
v8klla's Avatar
$1199.99 shipped for the QM...
P: 763-545-3800
Old 07-20-2007   #6
I've got a hybrid between the QM and PTT. Basically it's a QM twin rebuilt by PTT with their discs and TOB. It works very well and feels pretty similar to an ACT 2100. The bigger slave cylinder and PTT TOB are the keys to making it streetable. It was a lot more grabby with the shorter clutch pedal throw of the stock slave cylinder. I think you'd be happy with either QM or PTT, but opinions vary. It's the best clutch I've ever had.
Old 07-20-2007   #7
I am running the QM and am very happy with it. It is pretty grabby though, but I haven't switched over to the larger slave yet, but I will soon. It has its good and bad points. The good is that you have a nice light pedal pressure for a clutch that holds lots of power. The bad is the grabby part makes it not as streetable.
Old 07-21-2007   #8
The larger slave takes care of that completely. It also eliminates the need for a pedal stop, at least on my car. Pedal travel is like stock and it's not very grabby, or maybe I'm just used to it.
Old 07-20-2007   #9
What is the setup for the car, how much power, and how do you launch your car?
Old 07-20-2007   #10
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
2.4l project underway...
I figure at the very least 400 hp w/ 50 trim variant...
I'm going to need a new clutch and flywheel...
So I'm just getting a feel for what locals are running.
Old 07-20-2007   #11
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
I would like to be the first to say you won't need a twin disc then as there are plenty of single disc clutches that will hold that no problem.
'04 Honda Ricer: stock
Old 07-20-2007   #12
I run a 50 trim varient, and am running the X-Clutch. It's been holding fine for about a year now.
Old 07-20-2007   #13
Yeah, you don't need a twin disk yet, get a southbend.
Old 07-20-2007   #14
v8klla
v8klla's Avatar
What have people been able to make on the DSM southbends? Kyle had issues with the DXDSS before he even hit 350 ft/lbs...
We have run ACT 2600's to just over 400 ft/lbs at which time the street disc slipped, and the current 6 puck sprung is holding (kind of lol). Kyle ran a 2900 with both street and 6 puck discs and had slipping issues in the high 400 ft/lb range at which time we switched to the twin.
Chris
P: 763-545-3800
Old 07-20-2007   #15
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
We shall see what my clutch holds soon enough.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 07-21-2007   #16
I am running a southbend single disk in my car, and I should make a little more then 400lb/ft.
Old 07-21-2007   #17
v8klla
v8klla's Avatar
Can't wait to see how it holds up!
P: 763-545-3800
Old 07-21-2007   #18
Old 07-22-2007   #19
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
While it may appear that I don't need a twin disc setup for my setup, a twin disc system does allow future expansion possibilities. Thanks for the input guys!
Old 07-21-2007   #20
SBR_240sx
Send a message via AIM to SBR_240sx
PTT twin disc all the way.
SBR_240sx is offline   Reply With Quote
