Old 08-15-2007   #1
Enes
Enes's Avatar
polishing vibrator
You can polish parts a lot quicker and professionally! It is out of thick metal, a little bit of surface rust is pretty much nothing, with a can of paint you can make it look brand new. I will most likely end up doing that myself before its sold.
It was used by a local shop until it closed. It has a new motor in it, and comes with 180 Pounds
of stripping/polishing media, that alone is worth over $800
Dimensions:
29" x 18.5" x 19.5"
corner to corner you can fit in a part thats 34" long!!
The bad:
the lining around the drain started pealing a bit away but i will fix that before it is sold.
$700 gets you everything.
More Pics here
-Enes
Old 08-15-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: polishing vibrator
This thread is no where near as naughty as i thought it was be from reading the title GL with the sale e-man!
Old 08-15-2007   #3
Enes
Enes's Avatar
its pretty big, hell you could make a pleasure adapter if you want! .. get 2 things accomplished at the same time!!!
Old 08-15-2007   #4
It doesn't damage aluminum parts?
Old 08-15-2007   #5
Enes
Enes's Avatar
Depends what media you use.. there are dozens of other media out there that you can load the thing with ... and since it has rubber lining i don't think it will damage any part. But as i said, depends what media you use.
The media i have is for rough surfaces first. you would just need to get some finer media which is A LOT cheaper.
Plenty out there
polishing media on ebay
