Old 01-12-2009   #1
mike55112
mike55112's Avatar
Drives: 04 evo
Oil cooler elimination on evo
As some of you might know, I spun a bearing in my last engine. I need to replace my oil cooler and have been doing some research on evolutionm.net Alot of guys are saying that it would be ok to eliminate the oil cooler since its winter. Some even ran there cars without one in the summer as there daily driver. So my question is can I just plug the 2 holes or do I have to have a hose connect between the two? This is only going to be for a little while till I can find a affordable kit.
Old 01-12-2009   #2
Re: Oil cooler elimination on evo
I think that you could plug it, but do it well since it will see 100psi+.
My car takes forever to warm in the fall with the cooler so winter you will be fine, summer depends on what you do with the car and cool it manages to stay
Old 01-12-2009   #3
mike55112
mike55112's Avatar
Drives: 04 evo
It will only be for a while. I have to order a new oil cooler, once I get a new oil cooler it will go right on.
Old 01-13-2009   #4
I'd say you'll be better off to loop the outlet and inlet.
Old 01-13-2009   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Yeah I would think looping it would be a better option since it see's so much pressure. A plug would pop off alot easier.
-1990 Mitsubishi Cyborg 4WD-
Old 01-13-2009   #6
mike55112
mike55112's Avatar
Drives: 04 evo
Well I found a replacemnet cooler local so Im picking that up tomorrow morning and heading down to install it. Hopfully I can put the car on the dyno on thursday for a low boost tune.
Old 01-13-2009   #7
SICK!!!
I can't believe i haven't seen your car since you are somewhat local
Old 01-13-2009   #8
mike55112
mike55112's Avatar
Drives: 04 evo
SICK!!!
You probably have seen my car, I made 212awhp last fall dyno day and then made 252awhp at the cookout dyno day on the stock turbo.
