Old 02-12-2008   #1
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
catch cans?
What's the CORRECT way to run an oil catch can? there are 2 spots from the VC to go to the can-1 with a pcv. Does one just run both lines to the catch can? I hear you need a vaccuum source for it to work properly-is this true? any help is appreciated..thanks!
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 02-12-2008   #2
Re: catch cans?
Ideally you'd have 2 cans. One between the valve cover and PCV/intake manifold and one between the vc breather and intake pipe. I'm going to modify that a bit and run both my PCV and breather into one can and then route it to my intake pipe to use as the vacuum source.
Old 02-13-2008   #3
mdost03
Sonic Champion!
Drives: VA STI
Re: catch cans?
Make a catch can out of a gatorade bottle and a tiny breather filter from the autoparts store. They work wonders.
Old 02-13-2008   #4
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
Re: catch cans?
I'd really like for someone to take this serious and answer the OP's question. I'm interested in getting a proper catch can set-up as well.
If you could supply the good info, thanks to Kracka for some already, it would be appreciated! Possibly a link to the product if it's not too much of a hassle either!
Thanks!!
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 02-13-2008   #5
Re: catch cans?
Another thing to remember, you never want boost to enter the can and ideally you'll have a vacuum source attached to the can to help the crankcase breath and to clear gasses (the intake pipe works very well for this as does the intake manifold).
Old 02-15-2008   #6
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Re: catch cans?
I'm going to the GReddy sale on Saturday the 23rd. If they have a couple I will pick up a couple extra's and sell them cheap =)
Old 04-10-2008   #7
95talonracer
95talonracer's Avatar
Re: catch cans?
Anyone have photos of their setup as I am looking to properly hook up a setup like this. Can you Y the 2 off the valve cover into 1 into a catch can and have one vacuum line running from the intake sucking from both of these all the time or is that too much?
Amsoil Dealer
Old 04-10-2008   #8
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
Re: catch cans?
Heres how we 420a's roll. Whether this helps or not or is completely stating the obvious. Anyway
BLaCk_1cE is offline   Reply With Quote
Old 04-11-2008   #9
Re: catch cans?
From the Krank Vent thread...
http://dsmstyle.com/forums/attachmen...5&d=1206053635
Old 04-11-2008   #10
95talonracer
Re: catch cans?
Is there any good way to do it with only 1 can? Do you think that putting a small filter on the one and only hooking up a catch can to the other one and then routing it to the intake before the turbo will be enough?
Amsoil Dealer
