Old 11-27-2007   #1
1gGSX
1gGSX's Avatar
Conquset Injectors
I need two injectors for an 88 Conquest.
Let me know what you have
Thanks
Justin
1gGSX is offline   Reply With Quote
Old 11-27-2007   #2
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: Conquset Injectors
Do you mean one primary and one secondary?
Old 11-27-2007   #3
1gGSX
1gGSX's Avatar
yes, I have one injector that was in the back seat when I got the car but I don't know if it the primary or the secondary
Old 11-27-2007   #4
blackawdtsi
Drives: 2G DSM
Who needs two injectors!? Just throw one MSD in there! errr FIC errr...... derk err derrr
Old 11-27-2007   #5
1gGSX
1gGSX's Avatar
The funny thing is that there is only one injector in it and not the right one and I have to stay on the gas to keep it running
Old 11-27-2007   #6
Shotgun!
Totenritt
Shotgun!'s Avatar
So, you are driving it like that? What have you pluged the injector hole with?
Old 11-28-2007   #7
1gGSX
1gGSX's Avatar
There's another injector in there but not the right plug or the right ohms.
Can you get your hands on a couple or know somone who can?
Let me know
Thanks
Old 11-28-2007   #8
Wow, go here: www.starquestclub.com and read. Or save yourself the trouble and listen to me and Shotgun!
the black ringed one is the primary, it goes on the driver's side, and the car should start idle and drive without boost fairly well. the secondary has a green ring and goes on the passenger side. hook the other injector clip up to that one.
Who did you buy the car from, and can you take pictures of the engine bay up close and post them here?
details are key with quests.
if it really is just the injectors, you can get aftermarket ones that are new and will work way better than stock guys.
Old 11-28-2007   #9
dragonforce
pm sent.
dragonforce is offline   Reply With Quote
Old 11-29-2007   #10
blackawdtsi
Drives: 2G DSM
He doesn't have any stock injectors for it. He needs them. The guy he bought the car from decided to just throw some random FIC injector in it and run it like that. I had to drive it back like that, and the way he had it when we took it out for a test drive, there was gas leaking all over the place. I told the idiot to put a new injector seal in it.. He did so we could drive it back. However, the way you described it, the FIC is in the secondary position and the other injector just plugging the other hole is in the primary spot.
Old 11-29-2007   #11
Wow. www.starquestclub.com now. there are people selling stock injectors. 87 and up will work, 86 and below won't.
Like I said, there are some aftermarket options.
Old 11-29-2007   #12
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
If there is only an injector in the secondary spot I'm pretty sure the car would not run. The secondary should kick on at 3,000rpm, but will not run before that. Are the leads switched maybe? Sounds like a mess.
Old 11-29-2007   #13
No, they have a stock one in the primary position, and the single aftermarket one (probably the wrong size) running as primary in the secondary position.
Old 11-29-2007   #14
blackawdtsi
Drives: 2G DSM
There are NO stockers on the car. One injecter is just sitting there to plug the hole so no fuel leaks out. There only one running is in the secondary position. Maybe the leads did get switched, I have no idea. Hopefully Justin can get some injectors soon before any damage is done.
Old 12-03-2007   #15
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
I am also looking for a stock primary and secondary injector for a 88 Starion.
Preferably local. Pm me if y got anything.
turboDSM is offline   Reply With Quote
Old 12-10-2007   #16
hareboy1979
hey my brother has a parts conquest he should have what you need.
also are you the one that was selling jihanndude your starion cuz if you are my brother wants his turbo back he let julien borrow it to get that thing runnin then you guys backed out of the deal but either way the turbo wasnt his to send with the car.
thanx
jason
if you need to reach my brother regarding that injector his # is 952-484-5694
hareboy1979 is offline   Reply With Quote
