Old 03-20-2008   #1
1G N/T and Turbo fuel sending units the same?
My fuel level gauge wasnt working, so I pulled it. There is no continuity in it, the resitor wires that are coiled up are slightly burnt/corroded. Basically, I need a fuel sending unit, anyone got one lying around or at least know if the N/T is the same so i can pull one from a junkyard?
Old 03-21-2008   #2
Re: 1G N/T and Turbo fuel sending units the same?
Great question.
Old 03-21-2008   #3
blageo23
AWD4G64
blageo23's Avatar
I found a ton on tuners, Too bad you "dont have any money"
1998 Spyder AWD
567hp
490tq
Old 03-21-2008   #4
How am I supposed to know if they work!
Old 03-21-2008   #5
Buy one and try it!
Old 03-21-2008   #6
95talonracer
95talonracer's Avatar
I have seen someone makes an aftermarket billet aluminum one that way you won't have to worry about rust.
Amsoil Dealer
Old 03-21-2008   #7
if it is a fwd the n/a and turbo ones are the same
Old 03-21-2008   #8
I'm more specifically talking about the fuel level sender for the fuel level gauge Mine is burnt up and corroded, hoping they use the same sender from N/T and AWD...
Old 03-21-2008   #9
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Um, ask? JMO
Old 03-21-2008   #10
the sending unit for the fuel level in the tank is all the same for all 1g's n/t ot turbo
Old 03-23-2008   #11
Well, the resistor board thing of coiled wires (that the finger attached to the float rubs on to display the fuel level) was burnt/corroded and wasn't working. I searched the junkyard for all the early mitsu/eagle/hyundai cars I could find. They all use different fuel senders, BUT that little resistor wire board thing is similar. I thought to myself, well, lets try it. Sure enough, I installed one from an early Galant, and my fuel gauge works!!!
