Old 05-25-2008   #1
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
91 GVR4 - CV Axle And Intermediate Shaft Won't Seperate
So I have a 1991 GVR4 and I am replacing the left front CV shaft.
Everything went fine until it was time to remove the cv shaft/intermediate shaft. I knew they came out as a pair, so after removing the intermediate mount on the block, I tried to pull the whole assembly out. The CV shaft joint closest to the transfer case separated when I did that. I figured no big deal, as I was replacing it anyways. Well, I spent the next hour trying to get the remaining part of the coupler out of the intermediate shaft to no avail. The write up I read said that you grab the intermediate shaft and put the part that goes to the hub toward the ground and hit the area where they join with a hammer. I think the weight of the cv shaft helps separate them. I no longer have this "helper weight" to get them to separate. I tried placing the coupler resting on top of the vice and tapping the intermediate shaft downward as well.
Nothing has worked so far and I don't really know what to do. Any ideas?
Old 05-26-2008   #2
Re: 91 GVR4 - CV Axle And Intermediate Shaft Won't Seperate
That can be a real bitch to get apart. Best way I've found is to get a pry bar in there and just try to pry them apart.
Old 05-27-2008   #3
iceminion
iceminion's Avatar
take it off the car and have someone pound it off.
I have an intermediate shaft laying around, ill trade straight up so you dont have to worry about it.
building a 3000GT AWD Turbo.
Old 05-27-2008   #4
CarRacer
CarRacer's Avatar
Wow, thanks for the generous offer. I finally got it off. I just hit it with some authority. Everything went together fine and I replaced the lower balljoint while I was in there. 200k is about it for most parts. While I had the right side apart to fix that ball joint I noticed that cv boot is torn. At least I'll know everything is new.
