Old 05-07-2008   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Exclamation Reverse lights dont work!!
So rendomly like two weeks ago I realized that my reverse lights dont work anymore. My girl friend just bought a 96 eclipse and her's doesnt work either. Is this common on these cars? What should be the first step on figuring out what the hell is wrong?
The bulbs or ok and the wire's are ok to the housing. What makes the lights go on when you put it into reverse?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-07-2008   #2
Re: Reverse lights dont work!!
There's a swich on the transmission that may have come unplugged, or a wire is broken somewhere.
Old 05-07-2008   #3
GsXtUrBo98
GsXtUrBo98's Avatar
where at on the tranny ill have to take a look at it.
98 GSX (built)
03 BBY EVO dd
Old 05-07-2008   #4
I'm not sure where it is on a 2g, but on a 1g it's right on the top, kind of in the middle.
Old 05-07-2008   #5
same spot on the 2g as well
Old 05-07-2008   #6
GsXtUrBo98
GsXtUrBo98's Avatar
ok thanks ill take a look at it.
98 GSX (built)
03 BBY EVO dd
Old 06-08-2008   #7
GsXtUrBo98
GsXtUrBo98's Avatar
I see the plug in that you guy's are talking about but what would I do to replace it??
98 GSX (built)
03 BBY EVO dd
Old 06-09-2008   #8
Unplug it, unscrew it, buy a new one, screw it in, and plug it in.
Old 06-09-2008   #9
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Alot of people don't notice their reverse bulbs are out. You sure it's not just a bad bulb? If not then try the switch.. Other than that your going to have to start tracing wires.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 06-09-2008   #10
How many dsmers does it take to screw in a lightbulb? lol
Old 06-09-2008   #11
lol mine didnt work, was the switch.
Old 06-09-2008   #12
GsXtUrBo98
GsXtUrBo98's Avatar
I'm not too sure what you mean by unscrew it its just a plug in with wire's that disappear into the harness but I could be wrong I'll check again...
98 GSX (built)
03 BBY EVO dd
Old 06-10-2008   #13
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
get a deep socket, I can't remember what size it is (maybe 17?) and undo and unscrew it. The part under the switch is like a bolt head. When screwing the new one back in, be sure not to screw it in too much/too tight, otherwise the mechanism inside gets jacked, and the switch itself can snap off from the threads/bolt part.. trust me.
Old 06-10-2008   #14
GsXtUrBo98
GsXtUrBo98's Avatar
Ok i'll look tomorrow at what it will take thanks..
98 GSX (built)
03 BBY EVO dd
Old 06-10-2008   #15
4seasons69
4seasons69's Avatar
it's not that hard if you want some help I can give you a hand. let me know.
