Old 06-23-2008   #1
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Injector #3 Malfunction
95 Eagle Talon AWD 5spd.
Everything on the car is basically stock. Only upgrades done are:
Evo III 16g
Comp 101200 cams
3" exhaust
Walbro 255 pump
ACT 2600
I have boost set at w/g pressure which has come to about 6-7psi.
There is no check engine light, randomly I get the P0303 which is cylinder 3 misfire.
In return, the causes for that code include:
* Faulty spark plug or wire
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector
* Burned exhaust valve
* Faulty catalytic converter(s)
* Running out of fuel
* Poor compression
* Defective computer
So my first thought was replace the plugs and wires which I did, still misfires.
I replaced the Coil pack next, still misfires.
I replaced the FPR, still misfires.
I replaced the Injector box on the firewall, still misfires.
Threw AEM EMS in it, still misfires.
Replaced all injectors with FIC 850s, still misfires.
I dont have a catalytic converter but I've never heard of this causing a misfire.
O2 sensor is good.
Compression is 175-180 across the board.
Now this misfire is interesting, it only starts to misfire when I hit 7000rpm. Anytime before that it runs fine. But when I hit 7k, the misfire starts and it feels like I completely lose a cylinder.
If I put the car in neutral or push the clutch in and hold the throttle wide open, it takes about 10 seconds to clear out and it will rev just fine with no misfire until I bring it back up to 7k rpms.
The misfire is ONLY on #3 cylinder. I can swap plugs and injectors and wires and it still does it only on #3.
The other night I rev'd it up to redline until it started misfiring and went under the hood. You can hear/feel every injector firing EXCEPT #3.
So now I'm stumped. This was before and after I changed all that I changed out.
Anyone have any ideas? This is starting to drive me insane.
I raised the rev limiter in the EMS and it still does it right at 7k.
Originally Posted by shoutbox
Old 06-23-2008   #2
2bar1g
Drives: .
Re: Injector #3 Malfunction
Sounds like the injector clip or wiring to it is bad. I would check that to see if its melted/corroded/wires touching and whatnot.
2bar1g is offline   Reply With Quote
Old 06-23-2008   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
The clip is fine, I've checked that out to, I've moved all the wiring, around just havent opened up the harness yet.
What I dont understand is why only at 7k rpms.
Not 6k, not 6500, not even 6900, just when it hits 7k.
I'll rip into the harness sometime in the next few days. I really want this over with.
Old 06-23-2008   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Another thought I had would be cam sensor. But I would think that would kill all the injectors, not just one.
Either that or a bad ground somewhere?
And if the wiring was bad, why would it clear up after it happens?
Old 06-23-2008   #5
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Have you tried messing with the plug gaps? Probably have, just a thought.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-23-2008   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
100% positive its not the plugs.
I'll look into missing grounds and rip the wiring harness apart in the next couple days. The car runs just fine unless I red line it. Thats what has me stumped.
If anyone else has any ideas I'd be all for them...
Old 06-23-2008   #7
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Don't redline the car
pics or gtfo
Old 06-23-2008   #8
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I'm not... I cant even get it there. Redline is 7500!
Old 06-23-2008   #9
HiImBrian
HiImBrian's Avatar
I'm just kiddin jakey. Maybe you should give up and buy my car. Wanna buy my ecu and try that?!
pics or gtfo
