Old 07-20-2008   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
ACT 2100 project...
So my clutch has been slipping for about 2 weeks now and I knew it was going to have to happen sometime soon anyways, so I bought a new clutch and pp to put in. My rear main seal is leaking also so blageo and kevin both thought that that was actually the reason of the clutch problem.
Also, when my car would sit at idle it would make this chatter noise until I would push in the clutch then the noise would go away and it would get pretty annoying...plus my rear main seal was leaking so no matter what that tranny had to come out!
Blageo and I took the tranny out today and when everything was out after about 2 1/2 hours I found out that the clutch was actually really worn and the springs were loose, so we think that that was the issue with the chatter.
Once we were about to finish with taking the tranny out kevin (Sleepydsm) mike (mike55112) brandon (Greenhornet) and paul (HONDA) showed up and just bs'ed for a while before going out to eat..
So tomorrow the tranny goes to the shop and the clutch and rear main seal goes on the engine!! cant wait for this to get done and over with..
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-20-2008   #2
GsXtUrBo98
GsXtUrBo98's Avatar
Re: ACT 2100 project...
In case you were wondering I had the tranny rebuilt about 8 months ago and have been having problems with it grinding when going in to 1st so that is why it's going to the shop....
Also, when taking the fluid out it was like a brown color. Would that be anything to worry about or is that normal?
98 GSX (built)
03 BBY EVO dd
Old 07-20-2008   #3
That depends on the fluid that went in it, what kind is it? What should really get you worried is tiny brass flakes.
Old 07-20-2008   #4
GsXtUrBo98
GsXtUrBo98's Avatar
Not really sure on the fluid because it was put in when it was rebuilt and no there wasn't anything brass flakes...
98 GSX (built)
03 BBY EVO dd
Old 07-21-2008   #5
I have liked syncromesh, john shepard recommended it for my tranny. I have used Redline mixes, and I didn't like it.
Old 07-21-2008   #6
GsXtUrBo98
GsXtUrBo98's Avatar
Ok where do I get it at? Auto Zone, Napa, Checker???
98 GSX (built)
03 BBY EVO dd
Old 07-21-2008   #7
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
o'reilly's carries the synchromesh in stock at stores.
Old 07-21-2008   #8
GsXtUrBo98
GsXtUrBo98's Avatar
Ok thanks I'll either do the syncromesh or mobil 1
98 GSX (built)
03 BBY EVO dd
Old 07-22-2008   #9
GsXtUrBo98
GsXtUrBo98's Avatar
Clutch is finally in!!! and I went with syncromesh for the tranny fluid...
Also, forgot to mention when I took out the tranny I found out that I had a ACT light weight fly wheel!!! I was pretty excited for the lack of money that I was gonna have to throw at it
ID:	7572   Click image for larger version
Name:	ACT 2100 IN.jpg
98 GSX (built)
03 BBY EVO dd
Old 07-22-2008   #10
2100 in a gsx? I would have chosen a bit more aggressive clutch disc or pressure plate.
Nice car, good luck on the install.
Old 07-28-2008   #11
GsXtUrBo98
GsXtUrBo98's Avatar
Well it will do good for right now till I get a 6 bolt in there.... As for the 2100 I'm kinda scared about the crank walking so just to be safe, plus im not putting down enough power yet to really need anything more then that...
98 GSX (built)
03 BBY EVO dd
