Old 08-31-2008   #1
311evo
311evo's Avatar
evoscan not working.
i just recieved a cable to use with evoscan, and it will connect fine but then disconnect right away. and ideas on what i could be? thanks!
Old 08-31-2008   #3
Re: evoscan not working.
Restart the computer, restart the program, turn the car off then on again. I've had to use 1 of these 3 techniques every once in a while.
Old 08-31-2008   #4
311evo
311evo's Avatar
ive done all the things both of you said, still either connects and then the program freezes, or disconnects right away.
Old 08-31-2008   #5
311evo
311evo's Avatar
do you need both the black, and white plug?
Old 08-31-2008   #6
Yes, plug in both the black AND white plug, what does the status log on the right say as you connect?
Make sure you're only logging a few things...
Old 08-31-2008   #7
PS, moved to the right section
Old 09-01-2008   #8
311evo
311evo's Avatar
sorry about that.
and it doesnt have a white plug, so im SOL.
Old 09-01-2008   #9
Not necessarily, again, what does the log on the right say? Do you only touch your car at 4am? :P
Old 09-01-2008   #10
mdost03
Sonic Champion!
Drives: VA STI
I thought you said you had a Tactrix cable Jake? Doesn't EVOScan use it's own and aren't compatible with the Tactrix ones?
Old 09-01-2008   #11
311evo
311evo's Avatar
lol basically at 4 am give or take. it goes through all the connecting stuff, turns green for a second saying "connection successfull" then back to yellow saying "automatic recconnect attemp #x"
i think its fairly universal.
Old 09-01-2008   #12
311evo
311evo's Avatar
i couldnt get mitsulogger to work either..
Old 09-01-2008   #13
The Tactrix cable is the correct one for EvoScan, ECUFlash, and some other Subaru applications.
Old 09-01-2008   #14
Not necessarily. Where is the cable from? Gotta have the right drivers and the right hardware, otherwise it won't work!
Old 09-02-2008   #15
311evo
311evo's Avatar
uhh. rockjock on evomn. not sure its origin.
Old 09-07-2008   #16
blackrosenova400
blackrosenova400's Avatar
I run evoscan myself on my 1990 eclipse Gsx
In case you didnt know, you must plug the cable in first to the cars OB2 connector, then turn on your ignition or start the car, then connect it to your laptop and run evoscan.
If you have not tried it in this order, go try it, otherwise let me know maybe I can help you out later on in the week.
