Old 09-10-2008   #1
black2gst
Drives: 95 gst
95 gst rev problems
Its a 95 gst stock with stock boost.
Whenever the car idles revs will bounce to 2k then back down repeatedly. Although sometimes it wont do it at all or the revs may stay at 2k and slowly go back down to idle. Some people say IACV. any other input? btw whats the best way to clean out the IACV?
black2gst is offline   Reply With Quote
Old 09-11-2008   #2
Re: 95 gst rev problems
Do you have the water lines hooked up to the throttle body? If not thats probably it. Or you may have a bad idle controller (IAC/ISC), change it out with a known good one to see if it helps.
Old 09-11-2008   #3
Also check for boost/vaccuum leaks.
Old 09-13-2008   #4
black2gst
Drives: 95 gst
well it threw a code and it said "The PCM has determined that a malfunction exists in the idle control system."
