Old 09-07-2008   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
4 bolt rear end upgrades?
I currently was at the rock and broke some pinion gears in my 4 bolt, i have an extra one, and i also have a 3 bolt rear end. I herd that the 3 bolt gears are stronger than the 4 bolt gears. Do you guys know of any other upgrades i could do to my 4 bolt to make it stronger?
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 09-07-2008   #2
Re: 4 bolt rear end upgrades?
^that time is hauling ass. Also i heard there is a way of combining some of the 3-bolt internals with the 4-bolt ones to have a stronger rear end.
Old 09-07-2008   #3
I was told/read somewhere that the 3 bolt ring/pinion is a little stronger then the 4 bolt ring/pinion. So what I did was used a 3 bolt rear end housing, with the ring/pinion still in it, and put my 4 bolt diff and axles into it. For you its a cheap option as long as your 4bolt diff is still good.
Old 09-12-2008   #4
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
Correct me if I'm wrong, but aren't the ring and pinion shimmed to the case? So putting 4 bolt axles into the 3 bolt case is relatively easy and doesn't require resetting the backlash.
Old 09-12-2008   #5
Speedfreak
Drives: four tires
Shit, I didn't know the 3 bolt was any good.. I just recycled mine for scrap metal!
In any case, preload your drivetrain at the line, it will help save your parts.
Old 09-12-2008   #6
^how do you do that?
Old 09-12-2008   #7
Speedfreak
Drives: four tires
The simplest way is to pull the ebrake at the line and have the clutch let out a tiny bit(just enough for the car to be "pushing" against the brake). This effectively eliminates the slack or space between the gear teeth and reduces the amount of shock all the parts go through when you slip/drop your clutch for your launch. This is however a little abusive to your clutch.. Then you just have to get good at releasing your ebrake and launching at the green light and getting your hand to the shift knob in all one motion and all while not wasting any time..
