Old 09-17-2008   #1
brando
Drives: gutlass
4g64 crank
ok well im buying a 2.3 stroker and i need to find a 6 bolt 2.4 liter crank. what cars can i get these out of. i've heard the mighty max/d50 but is there anytrhing else that will work. any info i can get will be appreciated. thanks
Old 09-17-2008   #2
t_92r
t_92r's Avatar
Re: 4g64 crank
You can find one in a 1989-1991 Hyundai Sonata. Its a G4CS 6bolt block. The newer year have a 7 bolt block. You can check out this website (car-parts.com) to see if anyone have the or call the crankshaft supply in Minneapolis.
t_92r is offline   Reply With Quote
Old 09-17-2008   #3
Re: 4g64 crank
I don't think he needs a crank out of a narrow block 2.4, he should be able to get one out of a cheaper wide block. The mighty max/d50 is a good option or Mitsu had a minivan also that used that block. There is a ton of info on this subject, do a search on here or Google.
Old 09-17-2008   #4
Re: 4g64 crank
I would not matter wide/narrow block if you just want the crank, unless you plan to use the block and bolt a Getreg into your dsm.
Old 09-18-2008   #5
blageo23
AWD4G64
blageo23's Avatar
Re: 4g64 crank
if you are looking for a 6bolt
90-92 eagle summit, plymoth/dodge colt vista, mitsubishi expo
I have had good luck finding eagle summits at the junk yard. The block/crank in my car are out of a Colt Vista.
1998 Spyder AWD
567hp
490tq
Old 09-18-2008   #6
Re: 4g64 crank
Good luck on this one.
Old 09-18-2008   #7
v8klla
v8klla's Avatar
Re: 4g64 crank
These are getting next to impossible to find, especially locally. We have some brand new Eagle's in stock that I can let go for close to what you pay for a used OEM crank, let me know if that interests you.
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 09-18-2008   #8
Re: 4g64 crank
If you get a wideblock, I'll take that block off your hands.
Old 09-20-2008   #9
brando
Drives: gutlass
Re: 4g64 crank
will do
thanks guys for all the info. this really help's a lot and is why i love p[osting on this site.
i might call up you guys at ma here monday or tuesday and ask about your cranks. im not realloy nooking to make this a high buck build i would rather buy the parts from people.
again thanks guys
