Old 10-05-2008   #1
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
various 1g parts for sale
SOLD!
$40 - 1g pedal assembly for another $25 I can have it welded
$40 - 90 throttlebody
$40 - NT throttlebody - pending
$20 - 90 cam angle sensors
$5 - stock turbo outlet pipe
oil feed line
water to turbo line from waterpipe
$5 - stock 1g elbow
stock upper radiator hose
$700 - Brand New 1990 Transmission
$10 - stock mas sensor
$25 - stock radiator
$5 - 1g fwd tranny mount
$10 - stock headgasket from rebuild kit - SOLD
$5 - new water sensor (screws into thermostat housing)
$20 - fwd long drivers axle
$5 - stock 92 headlights
$5 - stock 92 driver corner
$5 - 1g clutch fork
$5 - ssac turbo outlet pipe -pending
$5 - stock coolant resevoir
1g fwd front mount
1g fwd rear mount
1g fwd tranny mount
Old 10-09-2008   #2
desolate
91 TSi AWD
desolate's Avatar
Re: various 1g parts for sale
I also have a 90 gst that I am parting out! Let me know if you guys want anything. Will have some pictures up soon.
Old 10-09-2008   #3
viridionplague
happen to have the driver side A-pillar, or the recirculation hose?
Old 10-09-2008   #4
desolate
91 TSi AWD
desolate's Avatar
pictures of 90gst before parting out
Old 10-11-2008   #5
I might be interested in the pedal assembly.
Old 10-11-2008   #6
desolate
91 TSi AWD
desolate's Avatar
sure, let me know.
Old 10-12-2008   #7
Do you know if there is any difference between the 90 and 92 pedal assembly? Also, what part actually gets welded, and what does that help?
Old 10-20-2008   #8
desolate
91 TSi AWD
desolate's Avatar
They are the same. The pedal assembly I have shown is actually from a 92 awd. There is a long metal shaft that ends with a machined rectangular end that the master clyinder arm slides onto, and over time and usage it becomes worn out causing slop in the clutch pedal before the arm actually depresses the master clyinder. To eliminate that slop from the pedal assembly there is a nut (size of a 14 socket). The nut on the end gets welded to the shaft. There is also a plastic bushing sitting very close by and you have to be careful while welding not to melt it or else you will need to rebuild the entire assembly. I had to do this on my car and after welding the assembly my clutch pedal feels 5x better.
Old 10-20-2008   #9
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
do you still have the stock flywheel on hand? What do you think you have for mileage on the street disk and pressure plate? What about a stock Fuel Pressure Regulator?
Old 10-20-2008   #10
mdost03
Sonic Champion!
Drives: VA STI
What about the wheels on the 90 GST? Those for sale or no?
Old 10-20-2008   #11
eclipse_spyder
The most ricest dsm
Those are Mazda RX7 wheels. Light and wide. 16x8+50 I think.
Old 10-21-2008   #12
desolate
91 TSi AWD
desolate's Avatar
The wheels are taken.
Old 10-21-2008   #13
Can i have the lids off the pop ups, mine are dented.
Old 10-21-2008   #14
desolate
91 TSi AWD
desolate's Avatar
Sorry, they were taken yesterday.
Old 10-21-2008   #15
viridionplague
ill take the trunk shocks and weather stripping if they are any good
Old 10-22-2008   #16
brando
Drives: gutlass
ill take the ssac outlet pipe.
Old 10-22-2008   #17
desolate
91 TSi AWD
desolate's Avatar
abs delete (4 hard lines and the proportioning valve) - $30
