Old 11-01-2008   #1
SmokingTires
SmokingTires's Avatar
Drives: Silver 2006 Evo MR
Tire tread height difference on AWD
Hey guys,
I'm just curious what you guys would do. I have two brand new Blizzak WS-50 and two lightly used ones. The new ones are 12/32 and the used are 9/32. 1/8 total height difference, or .5% overall height difference.
I've been brainwashed to believe in what the automakers say, not if you can help it. However on the Evo, I worry a bit. I have seen Audi's with AWD wear tires to bigger differences in normal driving.
Will I be find putting these on there? If so, where should I put the newer ones so they get worn down first (front or rear bias)?
Thanks,
-Mike
SmokingTires is offline   Reply With Quote
Old 11-01-2008   #2
Re: Tire tread height difference on AWD
You should be fine. .5% is such a minimal difference it won't matter. I would put the new tires up front.
Old 11-01-2008   #3
You'll be fine, it really isn't that much of a difference. Anything more than that and I'd say no.
Old 11-01-2008   #4
SmokingTires
I figured it's the difference between a couple pounds of air in the tires. Say, like the 3psi difference mitsu says to run
Cool, thanks guys. I'm putting them on this week.
Old 11-04-2008   #5
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
its fine for sure. the fronts will most likely wear out faster than the rears btw.
ლ(ಠ益ಠლ)
Old 11-04-2008   #6
Put the ones with more tread up front.
