Old 12-28-2008   #1
twack
It was a auto get over it
twack's Avatar
coolant temp sensor pigtail
Im looking for a plug and wires on the temp sensor. The highest plug on the thermostat. Mine is all mangled, o and its a 1g, Thanks
Old 12-28-2008   #2
iceminion
iceminion's Avatar
Re: coolant temp sensor pigtail
There are several other connectors on your engine wiring harness that you can cut off and use:
Coolant tank connector -low light never really works on 1G's
BCS connector -who cares?
the junk yard is also full of those wires on other Japanese cars
and you can always connect the wires individually with the spade connectors from the hardware store
good luck!
building a 3000GT AWD Turbo.
Old 12-28-2008   #3
twack
twack's Avatar
good luck!
thanks ill shop around the engine bay
