Old 08-31-2007   #1
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
clutch/tranny problem
I just installed a new South Bend OFE clutch and used tranny I got from another board member. After the install I took the car out for a quick test drive and first gear seems to not wanna grab right away. There's very little power and it seems to chatter for the first couple 1k RPMs. Then it grinds going into 2nd and 3rd is fine 50% of the time, 4th is fine but 5th sometimes grinds like it doesnt wanna go in. Besides bleeding the slave cylinder, what else could be the problem? Shifter cables maybe (or I hope rather than the clutch itself or flywheel, flywheel resurfaced to .610). I'm currently at school and will be off in by noon. So Im gonna go back home and try to get my car running. Any help will do. Thx
Old 08-31-2007   #2
Re: clutch/tranny problem
When i drove my car with that tranny in it, i loved it, the best tranny i have driven i even told my bro that we should tear it apart so i can compare the built one to that one, so that i could speed up the shifts in the built one.
Something is messed up on the install.
What fluid are you using?
Sounds like an engagement issue.
Old 08-31-2007   #3
I would bleed the clutch, check your pedal adjustment (engagement should be a few inches off the floor to make sure its fully released), and if that does not fix it, then a bad release fork, or a worn pivit ball, and the last thing would be a faulty install.
Old 09-01-2007   #4
1slowdsm
1slowdsm's Avatar
Would tightening up the PP a bit over torque spec cause an engagement issue? That's what I'm leaning towards right now. We couldnt get a hold of a torque wrench that would go to 10lbs (one I got from Napa loan-a-tool went from 30-250lbs). I kinda guestimated the lbs on it (one hand-tightening it with a ratchet, not trying to force it any tighter). I dont wanna mess up a good tranny, so I'm not gonna drive it anymore and risk grinding the gears. It's been a couple yrs since I've had a normal shifting tranny in my car .
Oh yeah, I'm running Royal Purple manual tranny fluid and the pivot ball is the same that Aaron (turbotalon1g) was using, so it should still be fine.
And another thing that I should add about first gear is that there's no power at all when engaging. I can full throttle it in first and it wont have the get up and go power, just struggle engaging. I'll be gone for the weekend for a tournament, so I'll come back on Sunday/Monday and probably take the tranny off and re-torque the PP to the right spec.
Old 09-01-2007   #5
Did you even get the PP all the way to the flywheel? I torque PP bolts to 18 lb/ft using red thread locker, and 1g flywheel bolts are 98 lb/ft using red thread locker.
Old 09-01-2007   #6
dragonforce
make sure replacement tranny is the same year. you might have to swap the shift cable bracket.
dragonforce is offline   Reply With Quote
Old 09-03-2007   #7
1slowdsm
1slowdsm's Avatar
replacement tranny is off a '91 awd and mine is a '93. I've been reading/searching and only found that '90 awd tranny shifter cables are different from '91-'94. The part where the cables connect to the gear selecting arms is a little different on one of the arms. It's maybe 1/2" longer than the ones on my old tranny. Instead of the cables being parallel together, one cable (passenger side cable) is at a small angle outward away from the other cable.
I guess to eliminate the possible problems I am going to just take the tranny off, tighten the PP to spec, then start putting it back together and see where that gets me.
Old 09-04-2007   #8
iceminion
iceminion's Avatar
its great using the stock torque specs on all the bolts, I highly recommend doing everything by the book
-BUT-
chances are that so long as you tightened the bolts down even half-assed, chances are that its fine, I would highly suggest to check for proper slave cylinder movement, pedal position first, you will feel like shit when you take your trans off just to tighten the PP an additional pound or so, and have it not fix anything.
-OR-
Just bribe one of us here on style who knows what they are doing to come take a look at your stuff. You might be making this more complicated then it needs to be
-AND-
as I understand it, when they switched to the 7-bolt (1992.5) they also made some chances to the transmission, for instance double synchro 2nd gear.
Most 91 transmissions are pretty beat up by now, its a possibility that your "new" trans is defective, used DSM transmission stories usually end badly, pay shep/TRE to rebuild it, you will not regret it.
But first do all the easy stuff.
building a 3000GT AWD Turbo.
Old 09-04-2007   #9
1slowdsm
1slowdsm's Avatar
Yeah, the last thing I wanna do is take off the tranny and redo everything all over again. I'm gonna have my younger brother come help me tomorrow and I'll check all the easy stuff. I need someone to step on the clutch while I inspect a few things from the engine bay.
The thing is that first gear feels like I'm not giving enough gas, even if I have the gas pedal all the way down and the only normal working gear is reverse.
And if anyone is around the Blaine area that knows this kinda stuff that is willing to come take a look at it I'll buy lunch or give you $20 if you can help me diagnose the problem. Give me a PM . I'm one of those broke ass college kids now that school started again, so I cant offer much.
Old 09-20-2007   #10
1slowdsm
1slowdsm's Avatar
K, so I went and got my flywheel measured by Andy at A&K Machines in Coon Rapids. He measured .605 on the outside part of the machined surface and .610 on the inside part. That would mean that my clutch 'wouldn't' disengage correctly, right? But then I'm having engagement issues in 1st, what does that mean? Since it's .610 towards the center of the flywheel is it still OK to use?
Old 12-18-2008   #11
1slowdsm
1slowdsm's Avatar
It's been a little over a year and I have the same clutch issue, ugh. That makes it 3yrs in a row that I've had a clutch problem...haha. I hate my car
As of the last time I drove it -> after doing a couple 3rd gear pulls against AllYouCanEat Talon, my clutch pedal lost it's normal resistance and wouldnt go into gear while the car is moving. Once the car is completely stopped it'll go into any gear like it normally would. I can put the car in first gear and start the car up and imediately drive in first gear only (not the best way I'd like to drive). So the transmission is still ok.
These are the symptoms of what happened last summer with my 2100 clutch kit, so my guess is that it's the same problem; my clutch disk is busted. So my question is...If this is the same problem is there any explanation for two broken discs within a year? I can just replace the disk and resurface the flywheel and problem solved? Or is there more that Im not aware of. Slave/mater cylinder seem ok.
The thing is I havent been hard on my car as bad as when I first had it and within the past couple years and I've gone through two clutches, the most ever. Maybe Im being too nice and my car doesnt like it :S (just a thought, hahaha)
Old 12-18-2008   #12
green hornet
make sure every thing is torqued right, with the new disc, also did you replace the TOB? maybe a bent clutch fork, i had alot of the same problems you are having with my FWD! i never found out what the problem was, after 2 trannys i scraped the dam thing and went to a 2g lol, i say check every little thing maybe you are geting air in your system? just a thought
Old 12-18-2008   #13
iceminion
iceminion's Avatar
while the transmission is off this time, you may want to file down all the rough edges on the synchro teeth, years of grinding actually wears the synchros incorrectly....so even if you re-assemble everything properly, it still might not work.
Check the tolerences on everything too, transmissions are (somewhat) easy
Old 12-18-2008   #14
Your clutch disk is dragging. I would check the slave and master cylinders to see if they are leaking. The master will leak above the gas pedal on the inside of the car and the slave will leak from itself. I would also try bleeding the system if neither of those appear to be leaking.
Old 12-18-2008   #15
1slowdsm
1slowdsm's Avatar
Im was on the edge of selling my car too, but I have to get my insurance money from when some kid ran a stop sign and caused us to collide. So Im gonna fix up my car for now and get something in the spring/summer. Maybe an Evo? lol. jk. That would be awesome. I'd like to stick with an awd, preferably a Mitsu.
Buuut. I'll for sure check the slave and master just incase there is a leak. I hope it's just one of those. I know the master cylinder has been leaking over the past few years, but the leak seemed so small I just left it.
The TOB was changed last year with the new clutch kit, so i dont think it has a reason to break unless its one of 'those times' with bad luck and such.
But thanks for the info. I'll hopefully get my car up and running again before the break is over.
Old 12-21-2008   #16
1slowdsm
1slowdsm's Avatar
Just checked the slave and master and they seem to be fine. No major leaking and the slave moves about an inch when clutch pedal is pressed. I read somewhere that you do a visual inspection of the clutch from a covered hole on the tranny, right? Or is it just the hole where the fork and slave meet?
Old 01-12-2009   #17
1slowdsm
1slowdsm's Avatar
Ok. hopefully this will be the last time I'll have to post about some transmission issue.
Well last week I got a working tranny in my car and all gears worked fine, just a bit rough and downshifting to 2nd and 1st at a stop is a bit tricky and rough at times. Reverse worked fine, but this morning when I was heading to school I couldnt reverse, so I was hoping maybe it was too cold so I drive to school anyway and at every stoplight I try going into reverse and it wont go in now. Reverse has been good all week, but now it just wont go in.
I've searched on here and came up with only adjusting the cables and clutch pedal, but still dont know why it would suddenly not work. All gears work and clutch engagement on the pedal isnt near the floor at all, so adjusting it doesnt seem like it would help.
Any ideas I can try once I get out of school?
