Old 03-27-2004   #1
santa
Boost Spike
santa's Avatar
well, heres the story my car is now not running. I got a new ecu cause well i needed a new one in the first place. two days ago I had to start leaving my negative terminal unpluged for a 1/2 hour and then connect and start it would start. now It wont start at all I'm lost on what to do. any ideas? its got spark and the fuel pump turns on. Im thinking about trying a new fuel filter, and well idk what else except maybe new injectors or something? well any help would be great thanks!
Old 03-27-2004   #2
Enes
Enes's Avatar
good luck on the fuel filter.. it is a PITA to install with trany in there..
-E
Old 03-27-2004   #3
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
It still doesnt run w/ the ecu?
'04 Honda Ricer: stock
Old 03-28-2004   #4
santa
Boost Spike
santa's Avatar
I've done a fuel filter before thats not hard at all... and yes cher it still wont start... I'm going to go after it with a test light today and see whats up... the fuel pump turns on theres spark but no start.... i have to check the return fuel line also see if theres anything pumping through it?
Old 03-28-2004   #5
Is it possible that this ecu is dead too? No CE light or anything?
Old 03-28-2004   #6
santa
Boost Spike
santa's Avatar
no ce light...its crazy...
Old 03-28-2004   #7
LightningGSX
Hellbound
Did you check for injector pulse?
-Nulli Secundus-
Old 03-29-2004   #8
If the pump turns on, it might be pressure related.
Check for fuel leaks (non sealed tank) etc...
check for ipw (like erik mentioned)
does the motor crank?
Old 03-29-2004   #9
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
What is you gas guage at?
Take her to the limit!
Old 03-31-2004   #10
santa
Boost Spike
santa's Avatar
ok well I figured out it is the computer. Heres the deal. I have to disconnect the negative terminal..for a 1/2 hour at least. then obviously plug it in and start it as fast as i can. I will start and run fine. i can turn the car off and leave the key in the on position so the computer doesnt turn off, and the car will start again no matter the time between, but if I turn the key only to acc. and the comp. shuts down and i try to start it once it turns off... she wont fire up...so I need to try a different comp...and that one i bough doesnt work cher...
Old 03-31-2004   #11
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Check the caps in the computer and the fuel pump relay. :goodluck:
