Old 08-15-2009   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
2g transmissions
ok i plan on picking up a 2g talon with no engine or trans my ? is could i just get a fwd trans and put the transfer case up to it ? are the fwd trans and awd trans the same as the fwd ... really like to know i have been working on 1g for awhile and now im getting a 2g so im trying to get idea what im getting into
all i know is u can not use a 1g trans in a 2g thats all i have found so far to answer my ? but its funny cause they look simular but differnt mount points
just looking for an eazy way to get this 2g running and on the road ...
the cheapest awd 2g trans is $700 and i dont want to pay that for one if i dont need to ....
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 08-15-2009   #2
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
Re: 2g transmissions
they arent the same the awd axles are skinnier if u call TRE they can give u a lot of facs about them or go to the teamrip website and go to facs
96GST16g is offline   Reply With Quote
Old 08-15-2009   #3
^^+1. You will need to use the FWD axles, and the transfer case won't bolt up to it, since the bellhousing is different. It should still bolt up to the engine and bolt into the car though, as far as I know.
Old 08-15-2009   #4
96GST16g
livin the dream
96GST16g's Avatar
could u change out the bellhousings?
Old 08-15-2009   #5
No, because the case and internals are also different because of the extra stuff inside for the AWD.
Old 08-15-2009   #6
95talonracer
95talonracer's Avatar
Dont go the cheap route it will just come to kick your ass in the end.
Amsoil Dealer
Old 08-15-2009   #7
I am sure you can put the transfer case next to the transmission. But as a Front Wheel Drive transmission is not intended to power anything but the front wheels, it lacks an output shaft and mounting hardware for a transfer case. Setting them next to each other is an option, but I doubt that is your original goal.
No they are not the same. One transmission is designed to power two axles (FWD). The other transmission is a FWD based transmission that also splits the power and sends it to an output shaft. From the output shaft it goes to the transfer case, sends it to the rear differential, and out to the rear axles. This is why they look similar as they are based on the same design, but a fwd transmission is essentially missing 1/3 the stuff an AWD transmission has in it.
A 1g DSM has 1 transmission mount on the vehicle. A 2g dsm has 3 transmission mounts. You are correct that they are chassis dependant.
Your best bet is to find another awd transmission cheaper. You could also put in a fwd transmission with a different axle configuration, but why even bother buying an awd chassis?
