Old 04-20-2008   #1
1G radiator fan won't turn on
Having radiator fan troubles on the 1G. Checked the fan, it spins if I wire 12v to it, no problemo. This is the stock fan on the passenger side, wired into the stock plug. What is it that makes this fan spin when the car gets hot, is it the ecu, triggered by the lower temp sensor? Sensor feeding the gauge seems to work just dandy, have not hooked up a logger to verify the other sensor is working. I have not tested the voltage at the plug, either. Just wondering if anyone has any suggestions to get this thing spinning!
Old 04-20-2008   #2
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: 1G radiator fan won't turn on
hey, im not positive but isnt the right side wired in for the a/c switch? I thought it was the secondary but maybe im wrong.
edit *Passenger side*
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 04-20-2008   #3
Side question, anyone know a good place to just hardwire the fan on when ignition is on?
Old 04-20-2008   #4
He is talking about the fan on the passenger side of the car which is the main cooling fan.
Old 04-20-2008   #5
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
^ Thats what im talking about, thats where mine was wired and it only worked with the A/C switch on...
-Matt
'06 Acura TL
Old 04-21-2008   #6
Maybe i am nuts, but I think the A/C fan is on the driver's side...its been too long!
Old 04-21-2008   #7
A/C fan was wired on the driver's side as far as I know.
Old 04-21-2008   #8
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
i dunno maybe its just been awhile since looking at it.. lol
-Matt
'06 Acura TL
Old 04-21-2008   #9
Swapped the relays and checked the fuses, still no go. I'm wondering if the pass side one *is* the a/c one. I'll try that tomorrow.
Old 04-21-2008   #10
wow. sorry to hear about your troubles, but you guys haven't gone crazy, the pass. side fan is the main fan.
Should turn on at about 203-206F
Old 04-21-2008   #11
It's controlled by the ECU, right?
Old 04-21-2008   #12
I believe the stock BCS is 12V that's comes on with the ignition. Not sure how well it can handle a fan though.
I believe the fan is simply controlled by that switch that is threaded into the bottom of the radiator on 1G's. Kyle mentioned something about being able to buy switches that thread in, but switch on at a lower temperature. Have you tried putting in a new switch? That may be worth a shot, and shouldn't take too long to swap in.
Also, just a dumb question, but are you overheating or anything? Do you know that the fan isn't running when it should be running? If it's not even getting up to the correct temperature where it should be turning on at, the fan won't kick on.
And yes, the passenger fan is the MAIN fan.
Old 04-21-2008   #13
There's a seperate temp sensor for the fans. It's on the lower radiator tank on the left side if you're standing at the front of the car facing the engine. The sensor is probably bad.
Old 04-21-2008   #14
Ya the car is def getting up to temp, and even overheating. I'll round up a new switch after I test for voltage coming out of the plug and the a/c thing.
Old 04-21-2008   #15
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Kevin has got it. There is a temp switch below the main fan. It's a small screw in type near the lower passenger side radiator mount.
I believe the plug for the ac fan is the same. You could plug it into that and keep the ac switch on as a temporary fix. You could also use the AC switch and drivers side fan wiring as a trigger with a relay off the battery. Then it would be controllable and could operate all the time. As an added fail safe, I'm pretty sure the AC fan comes on if the temp gets too high so even if you forgot the switch it would still come on eventually.
*edit* if anyone has a link for the lower temp fan switch I'd love one. I'd prefer it to come on in the 190 - 195 range.
Old 04-21-2008   #16
Kevin nailed it, I'd check the coolant temp sensor.
Old 04-21-2008   #17
Kevin you copy cat!
Old 04-21-2008   #18
Wow, 17 posts to figure out a bad coolant temp sensor. Mint.
Old 04-21-2008   #19
hahahahaha
Old 04-21-2008   #20
Mitsustyle FTW
