Old 09-30-2009   #1
DSM_brother2
Drives: to the shop
vac canister on 1g
do i need that vac canister on a 1g. its on the passanger side on the bottom of the firewall, it looks like it needs to stay?
Old 09-30-2009   #2
Re: vac canister on 1g
That's just the charcoal canister for the evap system. You don't need it.
Old 09-30-2009   #3
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
yea, if you take it out your check engine light will come on
but fuck emissions
Old 09-30-2009   #4
but fuck emissions
Since when? Mine never threw a CEL when I pulled it out.
Old 10-01-2009   #5
ROFLCOPTER!!!
I forgot about OBD1
Old 09-30-2009   #6
DSM_brother2
Drives: to the shop
alrighty. thanks guys!
Old 09-30-2009   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Your cel will not come on if you remove.. I don't know where you heard that from.
-1990 Mitsubishi Cyborg 4WD-
Old 09-30-2009   #8
on a 2g yes cel on a 1g no
Old 09-30-2009   #9
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Obd1ftw
Old 09-30-2009   #10
cmspaz
cmspaz's Avatar
If you pull the solenoids it throws a CEL, if you just cap off the vacuum lines it doesn't.
Old 10-01-2009   #11
^^ Again, that's only for 2g's. You can pull all that crap out of a 1g and no cel's will come on at all.
Old 10-01-2009   #12
DSM_brother2
Drives: to the shop
what about the stuff above the master cylinder??
Old 10-01-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Pull it.. It wont set off you're check engine light. The only thing I've heard that would set off you cel would be the stock boost control solenoid. Which is off my car but no cel. Check vfaq for the emissions remove diagram. It will show you everything you can remove.
Old 10-01-2009   #14
DSM_brother2
Drives: to the shop
alright thanks alot man!
