Old 03-25-2004   #1
Enes
Enes's Avatar
Ok, so if i remove my cat, the rear 02 sensor is going to burn out?
and it is going to give me SES light. correct?
-E
Old 03-25-2004   #2
JustROLLIN
SpunBearing
JustROLLIN's Avatar
On a 2g yes, it will.
Old 03-25-2004   #3
It won't burn out, but it will throw a CEL.
Old 03-25-2004   #4
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Good addition. Thanks.
Old 03-25-2004   #5
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
I think there is a kit you can buy to bypass that CEL for the second O2 sensor though isn't there?
CRAIG
Old 03-25-2004   #6
Who cares :0 Car will run the same, just pull the bulb out!
Old 03-25-2004   #7
CRAIG
DSMLink or an O2 simulator
Old 03-25-2004   #8
LightningGSX
Hellbound
Some resistors or a IC voltage regulator will do the trick.
-Nulli Secundus-
Old 03-25-2004   #9
Enes
Enes's Avatar
how much?
-E
Old 03-26-2004   #10
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Every car is different when it comes to CEL codes. I know someone on here who vents their bov and was driving around a while with the MAS unplugged without the CEL poping. It was a 2g. With the MAS plugged in it still doesn't go off with the bov. My car (2g) pops a CEL when just venting a bov. With my MAS unplugged the car will not rev past 2000 rpm.
7/25/09
Old 03-27-2004   #11
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
I still have yet to throw a single O2 CeL, like getto says, "It depends on the car". Do the "cat reduction" and see what happens, but I don't think it's a big deal.
Let the madness begin...
Old 03-27-2004   #12
LightningGSX
Hellbound
If you don't get a CEL, I would assume one or both of the o2 sensors are bad.Or I have read about pre-2000 Mitsubishi's having a problem with monitoring catalyst efficiency, more specifically the catalyst test hardly ever runs.
-Nulli Secundus-
Old 03-27-2004   #13
howslowcanyougo
Older than Dirt...
That's interesting, I'm getting alot of 0 volt readings on my front o2 in my DSMLINK logs?
Not always, just sometimes, but I guess it should never read zero volts. so it maybe bad?
Anyway so if the front one goes bad, can it affect the back ones operation?
TIA.....
Howie
Old 04-06-2004   #14
LightningGSX
Hellbound
If its an intermitent 0 volts, your o2 sensor is more than likely at fault.Or I guess the o2 sensor wiring is a possibility also.Due to the fragile and easily contaminated nature of o2 sensors the don't really have a long lifespan.
A missing or faulty rear o2 sensor may have effects other than the CEL.I can't say this is fact, but it seems to me, if an OBDII ecu see's a decrease in catalyst efficiency(faulty or missing rear o2 sensor), it may alter a/f ratios to try and bring the catalyst efficiency back up.Proper way to get rid of it, would be to note average rear o2 voltage(should be 0.6-1.0 volts) before you remove the cat.Then put a high wattage resistor(12 ohms IIRC) across the heater circuit, and another resistor(to drop voltage to previously noted voltage) between the b+ heater wire and the o2 signal wire.
-Nulli Secundus-
Old 04-12-2004   #15
Jacek
Captain J-Sack
is there such a thing as having to break in an o2? mine was flatlining when cruising but now is starting to work..
Old 04-12-2004   #16
Enes
Enes's Avatar
so when is that o2 simulator be ready?
-E
Old 04-14-2004   #17
GS_Turbo91
Guest
Tournaments Won: 6
Posts: n/a
2 of my buddies put in test pipes, one on an EVO and the other on a WRX. they put the O2 sensors back in, but with 1 or 2 washers on it to pull it out a little so it wont pop the CEL. both have had it like that for months now with no problem. just my 2 cents
Old 04-14-2004   #18
NSANE
I have had 2 2nd gen cars both with no cats neither one posted a cel not to say yours wont but once you get the dsm link you can turn off the cel for the rear o2.
Both my cars were 95s which is a bastard year not truely obd1 or obd2 but inbetween. That might have something to do with why it dosent through a cel.
NSANE is offline   Reply With Quote
Old 04-14-2004   #19
Enes
Enes's Avatar
yeah ONCE i get dsmlinkidylink... which is coming when btw?
-E
Old 04-15-2004   #20
95tsi
95tsi's Avatar
Drives: a pos
I have dsmlink with both O2 sensors and no cat. I've been running that for over a year with no cel's. I've had no problems with it at all.
