Old 10-02-2009   #1
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Looking for someone whos made the plate for FWD to AWD seal conversion
If you've made the plate that allows the AWD seal to seat properly in a FWD tranny or know someone who has please let me know because I am looking to make or get this plate but I don't have a pic for reference and probably don't have the tools to do it.
Old 10-02-2009   #2
bertrenolds5
Re: Looking for someone whos made the plate for FWD to AWD seal conversion
After much searching and e-mailing shep apparently all you need is the early 1g fwd seal part # MD707184 which is what the early 90 has. That makes things easier, so anyone with FWD equal length half shafts you can get the above drive axel seal for the drivers side and it should work.
Old 10-03-2009   #3
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I have the adapter out in the garage if you want some pics and measherments.
11.35 @ 120mph
Old 10-03-2009   #4
bertrenolds5
Did you use the awd drive axel seal? According to shep transmission the normal mitsu seal works just fine and does not leak, I hope. Do you have the mopar kit or is it one you made? If it's one you made I will def take a look at it. This seal # MD707184 is the FWD seal for all 1g's 90-94 I believe.
Old 10-04-2009   #5
carltalon
carltalon's Avatar
I used a AWD seal. I bought the adaptor from QPR way back in the day. But haven't run equal length axils since my trany sheared off 4th gear and screwed up the axil.
11.35 @ 120mph
Old 10-26-2009   #6
bertrenolds5
How did that happen? Wasn't because of the mod was it? Let me know why you sheared off 4th gear. I ended up using the stock FWD seal, it's what other people used and does not leak.
Old 10-26-2009   #7
carltalon
carltalon's Avatar
Originally Posted by bertrenolds5 View Post
How did that happen? Wasn't because of the mod was it? .
I was spinning in 4th and the gears sheard off not uncommon when you around 500HP
11.35 @ 120mph
Old 10-27-2009   #8
blackrosenova400
blackrosenova400's Avatar
I agree, unfortunately.
You rebuild yours yourself? Was this a stock transmission you blew 4th on?
Old 10-27-2009   #9
carltalon
carltalon's Avatar
It was stock. I just got a different stock one.
11.35 @ 120mph
Old 10-27-2009   #10
wants to be sideways...
123abc's Avatar
Drives: Loud cars
That sounds so insanely fun and stupid at the same time. Makes for a great campfire story though, eh?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 10-27-2009   #11
carltalon
carltalon's Avatar
Thats High HP FWD's for you. I was was street tuning 110 octaine before a dyno day. and 30 psi and street tires just didn't mix well. I had a good Oh shit moment last week When my car tried to change lanes into oncomeing traffic in 2nd gear. My heart was pounding for a while after that one.
11.35 @ 120mph
