Old 12-01-2009   #1
adidasdudegst
adidasdudegst's Avatar
Drives: 03 TB EVO
Project: 99 Eclipse GST Motor Pull and upgrade
Alright everybody, I'm finally getting the motor pulled out of my 99GST in the next few weeks. I'm bringing it to my uncles at Racing Engineering, where the motor will be stripped down, and many things will be refreshed and replaced as well as upgraded. I'm getting the FP 68HTA turbo already, and am looking for a good list of modifications to do to the motor while it is out. I'm still with the original 7 bolt, and it's at about 107,000 miles.
I would like your opinions on what some good mods and parts to replace are, besides the basics like the timing belt, cams and clutching equipment.
I'm upgrading the turbo, clutch and flywheel for starters...
adidasdudegst is offline   Reply With Quote
Old 12-01-2009   #2
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: Project: 99 Eclipse GST Motor Pull and upgrade
What are your goals?
Old 12-01-2009   #3
Get some cams, FP4R or HKS272.
Obviously you're going to need fuel upgrades, go with something like 1000cc and a Walbro255 pump so you can run e85.
That should put be most of what you need to put you in the mid or maybe high 300s on dynodynamics.
Old 12-01-2009   #4
Constant_Project21
Drives: E36
^^mhmmm, also need to think of what you're gonna tune with and a nice fmic setup as well. I know with my friends gst, that once they get 300+hp, you need to have your front end suspension and steering parts all in good working order, so make sure that maintenence is all up to date before slapping mods on. Fwd gets scary if not done right.
Old 12-01-2009   #5
Oh yea, the other mod is to go AWD!
Good call on FMIC and tuning, I'd recommend ECMlink for ease of use. Going to have to get a 95ecu though unless you want to get crazy and run an evo ecu or speed density or something.
Old 12-01-2009   #6
adidasdudegst
Drives: 03 TB EVO
Well, I'm good on the tuning, i have dsmlink, and plan on getting it professionally tuned at either MAP or DB in the spring, as I will basically have it put away for winter. I have a basic godspeed FMIC for now that I am going to sell eventually, and get a Greddy FMIC, and some short route dejon piping.
And yea, for goals, I want around 400hp. prolly end up with upper 300's, and I'd be more then happy with that, as it will be just for street use as a summer car for now.
Old 12-01-2009   #7
Fran05
Drives: DSM
68HTA is a very wise choice. It literally looks like a 14b or 16g, and makes one hell of a sleeper. Spools up faster than stock, and flows up to 48 lbs/min and costs only 800-900 dollars. What else could a man want to be happy?
Old 12-09-2009   #8
adidasdudegst
Drives: 03 TB EVO
alright, so now I'm thinking about really doing the motor up good, like around $3k worth, valves, cams, porting/polishing, crank, everything. What's a good person/place to have beef up a transmission? I know a shepard tranny would be awesome, but i really don't wanna have to do all the shipping stuff if possible.
Old 12-09-2009   #9
you will have to ship the tranny out to have it built
Old 12-09-2009   #10
Forced Fed
Drives: FS-T
-Forced Performance Intake tube with Recirc.
-Hallman Boost Controller
-Megan Racing Downpipe, Test Pipe, and Catback
-LIPP Cast O2 Housing
-Fel-Pro PermaTorque Head Gasket
-MSD or Taylor Plug Wires
-NGK BPR7ES Spark Plugs
-Hawver Cast Aluminum Intake Manifold
-JMFab Catchcan
-1350cc FIC BluMax Injectors
-DSMLink
-ETS 3.5" Intercooler
-Walbro 255lph Fuel Pump
-HKS 264 Intake Cam
-HKS 272 Exhaust Cam
-Forced Performance Cast Exhaust Manifold
Edit - Lol I only read the first post and thought this was posted today and not a week ago. Not sure if you are still wondering what a good set-up would be or not, but this is what I would build my DSM with.
Old 12-09-2009   #11
Constant_Project21
Drives: E36
-JMFab Catchcan
-DSMLink
-ETS 3" Intercooler
-HKS 264 Intake Cam
Why the Hawver cast mani? Just wondering.
If the shells clean, make it awd!! I believe it's easier on 2gs, if I remember correctly. Either that or really good tires, cause you're gonna be spinning.
Old 12-09-2009   #12
Forced Fed
Drives: FS-T
It is ugly but I like the design for a street car with a smaller turbo. Also you don't have to ever worry about blowing a weld, it cracking or having a pin hole leak in a weld. Kind of the same reasons I would get the cast O2 Housing and cast Exhaust Mani, just less to worry about.
Another thing would be MAPs Rev3 Intake Manifold, which I like even better now that I remembered about it.
Old 12-09-2009   #13
If you're only going for < 450whp, don't buy a built motor. Just do a stock rebuilt 6 bolt and save yourself the money.
Old 12-10-2009   #14
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Stock 6 bolt rebuilt. . .If done by a shop what would be the average numbers in cost, that one should be looking at. Just a rough estimate. I was quoted 3k by my parents local mechanics. I called them crazy and left. I am thinking about getting my 6 bolt rebuild. Just a Basic rebuild.
Old 12-12-2009   #15
adidasdudegst
Drives: 03 TB EVO
that's the thing, since I'm still with the 7bolt, i dont wanna put all that money into it, then have the damn thing crankwalk on me. My uncle owns a race engine shop, and the plan was to do a general full build on the motor... cook the block, port and polish head, cams, crank, pistons, springs and retainers, valves all that good stuff, but idk if I should still do it with it being the 7bolt...
Motor has to be pulled either way, to do timing belt, clutch and flywheel. So I figured since I got the FP 68HTA turbo, that building the motor up would be awesome so it could handle the turbo but its still a 7bolt...
Old 12-12-2009   #16
not all 7bolts walk. the evo 3 has a built 7bolt and has a very hard life and is still in great shape
Old 12-12-2009   #17
I'd say a refreshed 6-BOLT STOCK, with a nice headgasket, good tune, and some L19/A1 headstuds you can make really good relaible HP
I am on a stock 6-bolt shortblock, stock headgasket, regular ARPs, and my car makes 450awhp at DB no problem. I've been making over 400awhp for about a year now with no troubles. I did a stock rebuild with ACL Race bearings, new rings, honed the block myself, checked all the clearences, etc, and slapped it together.
My 2 cents.
Get a junkyard 6bolt. Freshen it up. Do the swap in your car, make it pretty. That Billet 16G, with some E85 would be fun!
Definitely need injectors over 1000cc if doing the E85.
One Walbro 255 HP is enough for your goals
I highly recommend the FP Race exhaust manifold.
Old 12-12-2009   #18
My refreshed stock 6 bolt by me has been making 400+ whp for over a year now.
Stock head (+cams), headgasket, shortblock
Arp regular headstuds, ACL race bearings
Stock rings, stock bore, oil squirters, no balance shafts
I would really suggest a turned down balance shaft instead. I hate the increased oil pressure that comes from eliminating them.
I say:
stock 6bolt swap
E85
Injectors over 1000cc
Single Walbro 255hp
ACT 2600 clutch and flywheel
*I've used both the fidanza and the ACT flywheels. I think the ACT is a more appropriate weight
*The ACT clutches are proven on DSMs. Get a sprung 6 puck disk, though
FP exhaust manifold
Don't really need an intake manifold, but it helps.
Cams. I have Brian Crower 272s (or get HKS) on stock springs and retainers. Works great.
Old 12-14-2009   #19
adidasdudegst
Drives: 03 TB EVO
I really appreciate the ideas! I believe I am going to stick with the 7bolt block... I already have a fidanza flywheel with a clutch I plan on using. Also got a 255hp pump, and plan on getting 1000cc+ injectors. Also do plan on getting an intake manifold, and fp exhaust manifold.
Here's a quick question, I'm selling my current FMIC setup, with all piping. I'm gonna go with short route IC piping, and a Greddy XL front mount hopefully... Is it better to stick with the stock 2g MAS or switch to a GM 3" MAF? I know the MAF runs in the IC piping vs. the stock 2g MAS being in the intake pipe right?
Old 12-14-2009   #20
rocket2g
Drives: 2g
yes. i say stay with the MAS. unless u already firgured out ur equipment. link?
rocket2g is offline   Reply With Quote
