Old 03-31-2010   #1
93tsiawd
Drives: 90 gst
7 bolt built block, 6 bolt stock head?
i was just wondering if the block is built does the head also have to be? or can it be safe stock? the block is a 7 bolt and rebuilt board.020 over. Fully balanced Eagle H Beam Rods, JE Pistons, Port and Polished Head, ARP Head Studs, Aluminum Crank, and Aluminum Pulley
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 03-31-2010   #2
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 7 bolt built block, 6 bolt stock head?
You can run a stock head on that block and be fine. It doesn't really matter. Now if you were to upgrade the cams, then you would have to probably get better springs so you could rev it higher into the power band. It looks like it is ported and polished head so that is a good start.
I would find a 7 bolt head though (93-94). I never tried putting a 6 bolt head on a 7 bolt block. should work?...
Old 03-31-2010   #3
93tsiawd
Drives: 90 gst
a 6 bolt head bolts up to a 7 bolt block
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 03-31-2010   #4
BogusSVO
BogusSVO's Avatar
Drives: 1985 Ford Thunderbird Turbo Coupe
yes it will.... but use the 7bolt 2g head bolt washers...
BogusSVO is offline   Reply With Quote
