Old 02-25-2010   #1
cleaning out the garage tons of parts
1g stuff
90 awd parts tranny (just ask)
90 awd welded center diff 100.00
right front knuckle 10.00
90 ''mitsubishi'' center tail light 10.00
cubby holes 5.00
90 fan blade rim center caps 30.00 set of 4
x2 red gas doors 10.00ea
X2 right door power window reg. 15.00 each
Left door power window reg. 15.00
Left and right door glass 20.00 per side
90 coil wiring and bracket 5.00
green left door handle 10.00
tranny mount frame rail 10.00
hatch release cable 5.00
90 turbo gauge cluster 10.00
2 din radio bez 5.00
gas/trunk levers and cables 10.00
front plate bracket 10.00
set of red door handles 20.00
cut cam gear cover 5.00
coil pack just 1coil 10.00
blower motor 10.00
p.s. heat shield 10.00
awd front roll stop mount 10.00
red power mirrors 10.00 ea left and right
white left door handle 10.00
crushed bov 25.00
upper motor mount 10.00
p.s. bracket 5.00
p.s. pump 25.00
x5 rear block mounts 5.00ea
front block mount 5.00
red pass fender needs work dented 10.00 1gb
maroon pass fender mint 25.00 1gb
3bolt rear axles non lsd 10.00 each
2g
brake master 10.00
brake resivoir and bracket 10.00
heater core 15.00
black hvac controles 10.00
x2 spyder top motors 40.00 ea
95-96 head lights 30.00 set
p.s. cooler 10.00
rear calapers left and right 10.00 ea
black radio bez 15.00
greddy mas adaptor 10.00
keyless entry ecu 10.00
air bag ecu 10.00
x2 clutch accumulators 20.00 ea
intake cam gear 5.00
recirc tube 5.00
4g63 and 4g64 engine parts
dohc 2.4 275cc injectors 25.00
dohc 2.4 intake manifold 2g head port size with 60mm plem 20.00
2g coil pack 40.00
2g water neck lower 10.00
crank pully 30.00
x2 2g crank sensors 25.00 ea
2g ingitor 10.00
2g water pump pullys big,small 5.00 ea
1g water pump pullys big,small 5.00 ea
7bolt fwd fly oem 20.00
x3 2g fuel rails 10.00 ea
x2 oem std size 2g pistons 10.00 ea
91-94 ignitor 10.00
7bolt ofh 10.00
6bolt upper water neck 5.00
1g o2 housing 5.00
90 turbo water pipe 30.00
2.4 dohc ofh 10.00
x4 alt brackets 5.00 ea
x2 6bolt n/a water neck upper and lower 15.00 ea
90 fuel rail 10.00
91-94 fuel rail 10.00
x2 2g t.b. no sensors 5.00 ea
x2 dip stick tubes 5.00 ea
7bolt ofh no water cooler or bolt 5.00
X2 6bolt awd oem fly 25.00 ea
oem clutch p.p 5.00
1g intake manifold oem 5.00
x4 timing belt tensioner arms 10.00 ea
b.s. belt crank pully 10.00
x2 new hydro tensioners 40.00 ea
x3 t-belt tensioner pully 5.00 ea
x3 t-belt idler pully 5.00
6bolt oil pick up 5.00
95-95 stock cams 10.00 set
7bolt arp head studs 50.00
6bolt 4g63 na oil pan 40.00
7bolt turbo oil pan's 40.00each x2
2g exhaust manifold 50.00
2g coil pack 40.00
2g inigter 15.00
2g t.b. w/tps and good isc 40.00
3g t.b. elbo 30.00
90 ofh for exturnal oil cooler 50.00
7bolt ofh 10.00 each x4
7bolt oil pumps 25.00 each x3
2g pistons 40.00 set of 4
2g pistons 10.00 each x3
evolution 3 pistons 75.00 set of 4
7bolt water pumps 10.00 each x3
2g valve cover 40.00
2g cam shaft sensor 20.00
2g cam gear sensor 20.00
2g crank sensor 20.00
cam gears 20.00 set x3 sets
2g block mounts upper 15.00 each x2
2g power steering pump 30.00
2g water pipe 15.00
91 turbo water pipe 30.00
2g abs pass axel reman napa 40.00
2g cams 20.00 set x3 sets
6bolt 4g63 na flywheel 20.00
7bolt fwd fly 20.00
7bolt awd fly 20.00
7bolt 2g blocks non had crank walk 40.00 each x3
7bolt evo 3 block has 1g oil squiters from mitsu. 75.00
2g head compleat ready to go 125.00
2g heads no valves good for a build 100.00 each x2
timming belt main pullys 20.00 each x2
other pullys just ask
Old 02-25-2010   #2
LingLing
AznKraut
LingLing's Avatar
Re: cleaning out the garage tons of parts
Do you have pictures of the JDM V.C.?
Old 02-25-2010   #3
it is the one on the 2.4 in the evo build
Old 02-25-2010   #4
I'll take the lower and upper steering column covers, why so much for a n/t Waterpipe though?
Old 02-25-2010   #5
ok just give me a call
the n/a one is the same price as the others and they are a little harder to find
Old 02-25-2010   #6
I need the 1g Coolent overflow! Also do you have a E brake lever and bracket? And finally I need the center console shift boot/cup holder peice that goes on top of the center console lower plastics.
Old 02-25-2010   #7
what is listed right now is pretty much what kevin and I found yesterday in the garage
Old 03-13-2010   #8
Just updated the list.
Will make deals if you want a few things. I don't want to move it to our new house in april.
Also looking for a set of 4*100 rims 15-17in.
Old 03-13-2010   #9
viridionplague
does the brake booster have the step in it? if so ill take the booster and the master
Old 03-16-2010   #10
stickyphoenix
The Wanderer
stickyphoenix's Avatar
Drives: '95 Eclipse GSX
Send a message via AIM to stickyphoenix
I will take the 2g shift knob off your hands if you still have it.
"My name is Jonas, thanks for all you've shown us!"
stickyphoenix is offline   Reply With Quote
Old 03-16-2010   #11
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
"eclipse 1g 5 piece front lights 25.00"
Is this the 1ga eclipse lights?
Still have these?
Old 03-16-2010   #12
the booster and master is out of a 1gb awd
still have the knob it is a non leather one
still have the front lights for the 1ga
pretty much if it is on the list it is still here
Old 03-16-2010   #13
viridionplague
well if you wanna pm me your phone number and address ill swing by tomorrow and pick them up.
Old 03-16-2010   #14
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
How good of shape is the 2g outer tails?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 03-16-2010   #15
Info sent
The tails are in great shape. They are off my car that has 38k on it
Old 04-09-2010   #16
updated list
added
6bolt block
2g head
1g head
Old 04-09-2010   #17
Buy some of this stuff, I'm sick of helping mark move it!
Old 04-09-2010   #18
lol, for some reason i wont be needing anything related to this list.
I'll put the word out i remember a guy on link wanting a flywheel
Old 04-24-2010   #19
Still have this stuff. Looking to go to canada soon to pick up a bunch of evo 1 parts for the new mirage.
Old 04-24-2010   #20
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
More info on this? eclipse 1g 5 piece front lights
-1990 Mitsubishi Cyborg 4WD-
