Old 09-01-2010   #1
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
1992 Talon TSi AWD Silver Shell
$350 (4-bolt is worth ~$200 )
My project car for the past year. 1992 Eagle Talon Tsi AWD (4-bolt). Planned to fix it up but went a different route (2g).
It will come with the 6 bolt shortblock on the car. Not sure of the condition, but it was smoking when I parked it last summer.
Some info:
I swapped the original seats with my 90 fwd. The seats are rare black cloth in great condition. A friend took the steering wheel, but it will come with one. It has the 4 bolt rear. The passenger side rear axle boot is torn, but car still functions fine, drives fine. Just the boot is torn. I was planning to replace that with a new boot/axle before I decided to park it. The two front axles are pretty much new. The brakes were also in great shape when parked. No problems with electrical, all lights & guages work, the wiring is in good condition. Had dsmlink in it previously. It ran a best of 12.6 @ 116mph @ RF last I took it out with the 16g. You will also not have any clutch disengagement problems with this shell because the clutch assembly has been welded (2-3hr job, pita removal). Had a act2600 on it and disengagement was perfect. There was a ton of adjustment afterwards. Also has a stainless steel clutch line (replaces the rubber). Slave cylinder is brand new with low miles as well. Has fuel pump rewire done good, all connections soldered. The body is in decent condition. Paint is faded in some areas, but doesn't look too bad. Front pass fender is bent in due to the door opening hitting it. There's a dent under the passenger door. You don't notice it unless you look under the car. No major dents on the body. The body is pretty straight. There is pretty much no rust on the car. The hood has some but that was because it was replaced.
What it would need to get up and running:
1. Tranny & Tcase (all axles there ready to bolt up)
2. Shocks & Springs
3. A good longblock + various things like intercooler, piping, mas
4. Exhaust
5. Fuel Pump
6. Headlights
Good solid project for anyone looking for a 1g shell with a 4bolt rear. You will have to bring some stock shocks and springs & wheels to roll it out. Title on hand & ready. Text or call 651-235-4595.
Some pictures of how it looks currently:
http://i260.photobucket.com/albums/i...alonshell1.jpg
http://i260.photobucket.com/albums/i...alonshell2.jpg
http://i260.photobucket.com/albums/i...alonshell3.jpg
http://i260.photobucket.com/albums/i...alonshell4.jpg
http://i260.photobucket.com/albums/i...alonshell5.jpg
http://i260.photobucket.com/albums/i...alonshell6.jpg
http://i260.photobucket.com/albums/i...alonshell7.jpg
http://i260.photobucket.com/albums/i...alonshell8.jpg
http://i260.photobucket.com/albums/i...alonshell9.jpg
http://i260.photobucket.com/albums/i...lonshell10.jpg
http://i260.photobucket.com/albums/i...lonshell11.jpg
http://i260.photobucket.com/albums/i...lonshell12.jpg
Pics of how it looked last summer:
http://i260.photobucket.com/albums/i...lonshell13.jpg
http://i260.photobucket.com/albums/i...lonshell14.jpg
http://i260.photobucket.com/albums/i...lonshell15.jpg
http://i260.photobucket.com/albums/i...lonshell16.jpg
http://i260.photobucket.com/albums/i...lonshell27.jpg
Old 09-01-2010   #2
Re: 1992 Talon TSi AWD Silver Shell
Any pics of the engine bay as-is (showing what exactly is still in there)?
Old 09-01-2010   #3
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
oshit. we should talk, maybe. who's got those parts!? hahaha
'04 Honda Ricer: stock
Old 09-01-2010   #4
I was wondering how long it would take Cher to hop in here.
Old 09-02-2010   #5
desolate
91 TSi AWD
desolate's Avatar
Haha, let me know. I can snap some pictures of the engine bay tomorrow.
Old 09-02-2010   #6
desolate
91 TSi AWD
desolate's Avatar
Snapped some more pictures of the engine bay area. The tbelt didn't snap, it was just cut. Won't be coming with the head obviously. As for other parts that will be missing, I'll be taking just the oil cooler out & crank pulley. I might take 1 or 2 extra parts out but it will be basically be sitting like this to go. Alternator, starter, & radiator are all there. Starter plate was originally for a fwd. I couldn't find one at the time so it was hacked to work with the awd tranny. Wiring harness was modified for a tuck look. Extended the CAS, and injector wires, all soldered/heatshrinked. All four motor mounts were also filled with window weld. Knock sensor is also new oem, prob has like 2k miles on it.
http://i260.photobucket.com/albums/i...lonshell17.jpg
http://i260.photobucket.com/albums/i...lonshell18.jpg
http://i260.photobucket.com/albums/i...lonshell19.jpg
http://i260.photobucket.com/albums/i...lonshell20.jpg
http://i260.photobucket.com/albums/i...lonshell21.jpg
http://i260.photobucket.com/albums/i...lonshell22.jpg
http://i260.photobucket.com/albums/i...lonshell23.jpg
How the engine bay used to look:
http://i260.photobucket.com/albums/i...lonshell26.jpg
Old 09-03-2010   #7
desolate
91 TSi AWD
desolate's Avatar
Aight $300! Could part it out for more but, $300!
Old 09-05-2010   #8
desolate
91 TSi AWD
desolate's Avatar
Bump, if nobody takes it 1 week from today then it will get parted some more.
Old 09-05-2010   #9
Chim55117
Drives: 2007 BMW 335i Coupe
I've got dibbs on the shortblock for $100 if you part.
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Old 09-06-2010   #10
Drives: 98 iVTEC
If i had wheels/suspension for it, i'd probably take it..
Old 09-06-2010   #11
Speedfreak
Drives: four tires
I'm sure all that can be found for dirt cheap(just stuff to get it rolling).
There should be an option to "Delete" posts.. As after I posted this, was wondering if the wrath of Kracka would put the smack down on this post.. So then said F it and tried to delete, but no obvious option to do so that I can see.
Old 09-06-2010   #12
desolate
91 TSi AWD
desolate's Avatar
Exactly.
If you really want it, you'll find a way. Simple as that, really.
Soo.. if anyone wants it, jusssssst come get it. You know what you have to do! Great deal as it is imo
Old 09-06-2010   #13
93gtpeater
Drives: cbr 1000rr repsol
I have wheels and struts that can be used to make it a roller.
Old 09-08-2010   #14
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
I have a complete used custom turbo-back exhaust system. Not name branded, but no leaks, and works great.
Someone should pick this thing up. Winter is on its way!
Old 09-08-2010   #15
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
If you do part it out I'm interested in some more parts.
Old 09-16-2010   #16
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Called and left a message, hopefully you still have it..
Old 09-24-2010   #17
Chim55117
Any updates on this? I'm still down for the shortblock if you're parting it out soon!
Old 10-05-2010   #18
Gvr-4
Is this sold? I've been waiting for the part out too.
Gvr-4 is offline   Reply With Quote
Old 10-08-2010   #19
desolate
91 TSi AWD
desolate's Avatar
Ok it's getting parted out more.
PM LMK what you guys want!
