Old 07-15-2010   #1
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
FS: 6 bolt short block, 14b turbo set-up, 22 spline t-case (Alexandria)
Stock 6 bolt short block with approximately 100k on it. Cylinder walls look very good on it. $300
TD05H 14b, stock o2 housing, 1g exhaust manifold, stock compressor housing elbow, and all water and oil lines. $100
22 spline t-case with approximately 100k. $100
90' oil filter housing with the appropriate and hard to find 3/8 BSPT to 8 AN fittings. $50
2g awd big brakes. Calipers, lines, and rotors. $150
1g intake manifold. $20
Jungy is offline   Reply With Quote
Old 07-16-2010   #2
Jungy
Jungy's Avatar
Re: FS: 6 bolt short block, 14b turbo set-up, 22 spline t-case (Alexandria)
I also have a 90' oil filter housing with the appropriate and hard to find 3/8 BSPT to 8 AN fittings. $50
Old 07-16-2010   #3
Galant409VR$
Galant409VR$'s Avatar
Drives: 1991 Mitsubishi Galant VR4 409/2000
Is the turbo in good shape? Any shaft play or is it craked at all? How much for thr turbo water and oil lines and that compressor elbow?
Thanks
Galant409VR$ is offline   Reply With Quote
Old 07-16-2010   #4
Jungy
Jungy's Avatar
I haven't separated the turbo from the manifold so I'm not sure if there are any cracks in the turbine housing. I would like to just sell it all together for $100, I consider it a fair price for everything and I just need to clean up the garage.
Old 07-17-2010   #5
DSM_brother2
Drives: to the shop
90 ofh come with everything needed? cooler and etc?
93 talon tsi/ 6 bolt swap
Mitch
Old 07-18-2010   #6
Jungy
Jungy's Avatar
Just the OFH with the 8 AN fittings for the cooler and 4 AN fitting for turbo feed, I don't have the cooler or lines.
http://www.machv.com/exoilcoolfil.html
Old 07-22-2010   #7
Jungy
Jungy's Avatar
All prices are OBO so make an offer!
Old 07-22-2010   #8
gohan2058
gohan2058's Avatar
Drives: Stealth TT/Eclipse GS-T
Send a message via MSN to gohan2058 Send a message via Yahoo to gohan2058
would you part with the oil drain off the turbo? I need the part for a 6 bolt swap but i already have the 14b turbo and all the other lines. hit me up plz I need to get this done 651-261-7169
gohan2058 is offline   Reply With Quote
Old 07-22-2010   #9
Jungy
Jungy's Avatar
I would really like to keep it together and sell it all as a whole. If it comes down to it I will let you know.
Old 07-23-2010   #10
Jungy
Jungy's Avatar
Pics added + 2g awd brakes to first post.
Old 07-27-2010   #11
Jungy
Jungy's Avatar
14b sold and OFH sale pending.
Old 07-29-2010   #12
throwedgsx
throwedgsx's Avatar
Drives: 09 Mustang GT, 98 Lumirod
i am interested in your 6 bolt block. I will drive the 3 miles to your house to pick it up.
'95 TSi AWD
throwedgsx is offline   Reply With Quote
Old 07-31-2010   #13
Is that a running 6 bolt? Ready to drop in?
Old 10-18-2010   #14
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Do you still have the 90 OFH? I will drive the 3 miles to pick it up
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
