Old 11-04-2010   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
1 week turbo went bad after rebuild
i have a fp turbo 60-1 with a mitsu center cartrige and td06h wheel
i just had it rebuilt by diesel components worked great after that
the only thing i changed was the oil feed location i changed it back to the head and i thought that would take care of my oil seals blowing ran great affer i swapped it no smoke anymore now as of last night it quit spooling all together i just spent 300$ on this to get it going again what am i doing wrong to keep smoking turbos huge shaft play it ate the compressor wheel dont know about the exaust wheel havent pulled it off yet i dont have a turbo timer but i did sit for 1 min everytime before i shut it off the car and allways let it warm up for 5 min
the engine dosnt tick or show signs of oil starvation running 10w40 oil orily brand non syn still new engine about 2500 miles since rebuild changed oil 14 times the only thing i can come up with is the oil pump is weak ? after its warm it the manual gauge reads 20 then in boost maxes out at 80 never hits a 100 cold .
id like to know what i am doing wrong here
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 11-05-2010   #2
twack
It was a auto get over it
twack's Avatar
Re: 1 week turbo went bad after rebuild
would be on the phone with diesel components and see what they say. best place to start
Old 11-05-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Your oil pressure seems to be perfect for feeding the turbo from the oil filter housing. I wouldn't feed from the head with that pressure.
-1990 Mitsubishi Cyborg 4WD-
Old 11-13-2010   #4
Check the feed port at the head, might be plugged with build up. Do you know for sure oil was flowing from it?
