Old 11-10-2010   #1
SpyderGSX07
SpyderGSX07's Avatar
Drives: 97 GSX Spyder/99 Chev S-10
powerband cuts out around 5 psi
my buddies 95 eclipse gst powerband seems to be cutting out once under boost. it seems to slowly die down to 5psi and holds there. The motor sounds like the ignition is cutting out and it is really boggy. and every once in a while it will backfire under this boost. could this be something to do with the coil packs? or something completely different. Thanks!!
SpyderGSX07 is offline   Reply With Quote
Old 11-10-2010   #2
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Re: powerband cuts out around 5 psi
Is it still running under MAF? Sounds like it's a massive boost leak sonnnnnn!
2010 Evo X GSR
1997 Subaru GC8 STi
Old 11-10-2010   #3
SpyderGSX07
shit. i suppose that makes sense. yes it is running the stock MAF.
Old 11-10-2010   #4
95talonracer
95talonracer's Avatar
Always do a boost leak test first thing and then go from there.
Amsoil Dealer
Old 11-11-2010   #5
Replace plugs, make sure they are gapped correctly, boost leak test.
Old 11-16-2010   #6
SpyderGSX07
problem solved. coupler wasn't sealing for shit. Thanks!
Old 11-16-2010   #7
DoughtCom
DoughtCom's Avatar
Drives: Your mom
Rock n Roll son, glad it was something easy.
2010 Evo X GSR
1997 Subaru GC8 STi
Old 11-17-2010   #8
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Boost leak test they are like Miracle diagnostics lol
